Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L )
Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) Nokia Legacy Models Like 1011, 1610, 211x, 2x20, 6050, 3110, 8110, NKxxx , 2100, 3210, 3310, 3330, 3410, 5110, 5210, 5510, 6110, 6150, 6210, 6250, 7110, 8210, 8250, 8850 also 9110 & 9210
Old 08-29-2000, 01:02   #1 (permalink)
neb
Member: 751
Thanks Meter: 19
Post "help contact service"
Hi All,
I need help, 5110 v5.28 on “contact service” not caused by improper unlocking, run mcu self test on wintesla, all fields passed except for eeprom sec checksum which failed. Checked lock condition with NokiaTool, all locks closed and can’t be unlocked by any software and unlocking trick.
Wintesla
MCU self test:
All fields ----------------passed
Eeprom Sec Checksum----------failed
Nokia Tool
MCC+MNC EEEEE U CLOSED
GID 1 FFFFF U CLOSED
GID 2 FFFFF U CLOSED
M EEEEEEEEEE U CLOSED
I saved the eeprom data and upload new data from working phone…Run Factory Default Settings on wintesla..”Contact service” removed, but all locks were still closed and still cant’ be opened… I even tried to remove and change flash ic with lower version but still all locks can’t be opened…….Any solution !!??…
Regards,
neb
Old 08-29-2000, 10:37   #2 (permalink)
MDR
Member: 1272
Thanks Meter: 3
Post
unless you have a TDF4 sec box, its goodbye phone.
another drastic soulution is to change all the eeproms.... but still, i think, you would need the sec box.
Old 08-30-2000, 09:55   #3 (permalink)
Member: 1562
Post
Hi,
I have a very strange experience with CONTACT SERVICE problem. A guy gave me a 5110 v5.28 to unlock. Connecting pins 6&7 didn't work, and moreover the phone said contact service. But when I desoldered the wires and put all back together the phone was OK. After that the guy told me that he had the sp unlocking code (which he got from the provider) and that he tried to enter it into the phone, but it didn't work.
After all of this, I have no will to mess with this piece any more. Anyway, I'd like to hear some comments about this.
B.R.
Galussa
Old 08-30-2000, 21:28   #4 (permalink)
Y2K
VIP-Member
Member: 69
Post
to neb
the problem is stored in the COBBA!
there where the locks dammaged ;-(
you can try to bring it in a service center and maybe it will have a little chance after a software update, but this is in 98% not working!
for this you need more then the tdf-4, sorry think the mobile is dead for home workers!
to MDR:
please let me know what for you need the TDF-4 this is flash security box!?
best regards
Old 08-31-2000, 15:54   #5 (permalink)
gab
Member: 1042
Post
Hi!
I think your eeprom dump damaged ..it has wrong checksum...
Please send me your eeprom dump!
I will fix it!
After upload the phone and phone working again!
Dont use wintesla or other tools!
regards
Old 09-02-2000, 12:58   #6 (permalink)
neb
Member: 751
Thanks Meter: 19
Post
Thanks to all who share their ideas on how to fix "contact service"....But Gab's method works!!Thanks man!
[This message has been edited by neb (edited 02 September 2000).]
Old 09-10-2000, 05:57   #7 (permalink)
neb
Member: 751
Thanks Meter: 19
Post
Hi Y2K,
Yes.. not all contact service problem can be normalized by "CSR".It depends on the degree of damage inflicted on eeprom data. I have another case, after repairing the "original" dump, contact service was removed but all locks were closed and can't be open again by any software or trick..
As you point out that the problem was stored in COBBA..Does changing of said IC NMP4370485 will solved the problem?!
Regards,
neb
[This message has been edited by neb (edited 10 September 2000).]
Old 09-11-2000, 23:50   #8 (permalink)
Member: 719
Question
hi neb,
does it accepts sim card when contact service is removed? mine doesn't accept any , have you tried replacing the COBBA?
regards,
koloksky
Old 09-12-2000, 01:27   #9 (permalink)
neb
Member: 751
Thanks Meter: 19
Post
Hi Koloksky,
All locks were closed...So, likewise doesn't accept any sim card anymore!
With regards to changing of COBBA, I haven't tried it yet...I doubt if it will solved the problem.
Old 09-12-2000, 12:41   #10 (permalink)
Member: 1480
Post
Hi GAB,
What do you use for fixing "Cont.Service" ?
Is it >Nokia repairer by Guar v1.0< 105 KB
or something else ?
ZiKa
Old 09-12-2000, 14:34   #11 (permalink)
X-Shadow's Avatar
Member: 871
Thanks Meter: 602
Post
Hello Guys,
Guar Repairer only works for checksum
problems. Even if you have the correct
checksums, but have incorrect Security
Bytes (First 11 or 12 bytes in EEPROM before
first IMEI), your phone will still be locked!
This is the harddest part of the EEPROM I
think.
I have this problem with an old 6138 v5.01.
I has been dead for more than a year now, and
still upto today I try to fix it with no
luck I managed to rebuild the IMEI and
the locks, but this is all useless without
the right security bytes.
I think changing the COBBA will not help.
Your phone will still be locked. Changing
flash to lower and unlock will also not work
because the problem is in the EEPROM not the
phone version. I think nokia service can
still fix it, that is if they are WILLING
to fix it
Best Regards,
X-Shadow
Old 09-15-2000, 20:33   #12 (permalink)
Bph&co
Guest
Posts: n/a
Member:
Post
Hi,
I think that Cobba and the serial sharing in
some way the security of the phone. I had
many barred Nokias(51/61). I had also few broken boards which a used for parts. So when I get Flash and Cobba, and the eeprom dump and put it on the barred board - that's
a new phone. I've tryed it many times. Other
thing is that if the both boards are one and the same SW, maybe don't need to change the Flash chip, just Cobba and the serial(??).
If the damage in the serial is so bad maybe
changing the Cobba and writing the new eeprom will help. And they must match( to originate from one and the same phone).
Other way is if somebody has a really detailed map of the eeprom, I've never seen it yet.
Best Regards
Old 09-16-2000, 00:45   #13 (permalink)
neb
Member: 751
Thanks Meter: 19
Post
Hi Bhp@co,
The first part of my dump were damaged, the part before the first IMEI, I asked the opinions of "CSR" authors and both of them said that, that part was written with unknown algorithm yet so they can't rebuild the lost data as of this time.
Changing of COBBA and copying of its serial pair is my only way to normalize the phone as you mentioned. Desoldering of the said part is difficult but I have to try.
Big TNX to you and to the rest who gave their opinions.
Regards
Old 09-18-2000, 13:49   #14 (permalink)
neb
Member: 751
Thanks Meter: 19
Post
Hi Bph&co,
Your are absolutely right! Big "TNX" once again!!
Old 09-23-2000, 23:29   #15 (permalink)
Crazy Poster
Member: 2038
Question
can anyone tell me where I am going wrong with contact svc soft , I read and save eeprom open prog select file and get message
"wrong file" am I doing somthing wrong?
Help appreciated..
Plz help, contact service 6280 suhail1 MT-BOX 6 06-18-2007 10:23
HELP! ! ! ! Contact Service - Keyboard Stuck Test failed. Phantom Nokia Hardware & Hardware Repair 0 04-22-2006 19:45
Help ! Contact Service on 8210 ! unlockphone Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-23-2001 23:52
Help contact service on 8210 amb Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 04-24-2001 11:59
help! contact service 5.28 5110! koloksky Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 06-23-2000 15:43
Page generated in 0.38399 seconds with 9 queries
