07-28-2001, 17:56 | #1 (permalink) |
Junior Member Join Date: Jul 2001 Location: Calico Rock, AR
Member: 5498 Status: Offline Thanks Meter: 0 | Help me unlock my Nokia 5190 |
07-28-2001, 20:44 | #2 (permalink) |
Insane Poster Join Date: Jul 2001 Location: UK
Member: 5229 Status: Offline Thanks Meter: 1 | Hi<br />I found this for you, read it and make your own mind up as to whether or not it will work. I have a 5190 SW 6.11. Nokall did not do the job on this phone. If you have <br />software older than 6.11 I would try Nokall first. <br />For 6.11, there are two websites that describe the procedure that worked <br />for me in quite good detail. They are for the 5110, but the 5190 is very <br />similar. The procedure is well established for the 5110 and quite safe, at least<br />much safer than flashing : <br />Illmatic's German Site <br /><a href="http://home.talkcity.com/MigrationPath/fairfax4ayaj/" target="_blank">http://home.talkcity.com/MigrationPath/fairfax4ayaj/</a> Go to Unlock, Nokia 5110 v.5.29. I followed the instructions here. <br />In contrast to the picture, my EEprom was turned 90°, but Pin 5 is just the <br />pin diagonally across the marked pin 1. <br />In case you do not know German, the site below describes a similar <br />procedure, <br />but instead of shorting pins 6-7, you have to solder an insulated wire with <br />a 10 pF capacitor to pin 5, <br />put the capacitor to ground. Unlock 2-3 times. remove the capacitor from <br />the wire and unlock all <br />locks one more time. Worked like a charm for me! Dutch site in English <br /><a href="http://members1.chello.nl/~r.djoniman/Nokia/unlocking_v5.htm" target="_blank">http://members1.chello.nl/~r.djoniman/Nokia/unlocking_v5.htm</a> If it works for other people (which I am sure it will, if it is done correctly)<br />post it here, so that other people can see it.) Good luck <img src="wink.gif" border="0"> |
06-25-2003, 03:05 | #3 (permalink) |
Junior Member Join Date: Jun 2003
Member: 32436 Status: Offline Thanks Meter: 0 | Can someone please email me with info about how to unlock a Nokia 5190, Type NSB-1NX, IMEI: 010063/50/256961/5 Code: 0502040 FH02T26. [email protected] THANK YOU! I know nothing about this stuff! I'd really appreciate some assistance. BS |
06-25-2003, 03:07 | #4 (permalink) |
Member: 32436 Status: Offline Thanks Meter: 0 | Can someone please email me with info about how to unlock a Nokia 5190, Type NSB-1NX; IMEI: 010063/50/256961/5; Code: 0502040 FH02T26. [email protected] THANK YOU! I know nothing about this stuff! I'd really appreciate some assistance. BS |
06-25-2003, 10:38 | #5 (permalink) |
No Life Poster Join Date: Aug 2001 Location: Roma Age: 49
Member: 5926 Status: Offline Thanks Meter: 275 | This post is 2 years old! and is so simple now to unlock dct3 phones anyway 5190 will work only on 1900MHz networks (american networks) for tool use search function and you will find hundreds of threads and links too. BR Rak|m |
07-29-2003, 22:02 | #6 (permalink) | |
Junior Member Join Date: Jul 2003 Location: Toronto
Member: 35839 Status: Offline Thanks Meter: 0 | 5190 Unlock Q&A Quote:
I am going to purchase the cable today and want to make sure I have the right software. Also, do I have to have the sim card that came with the phone to do this? | |
07-29-2003, 22:22 | #7 (permalink) |
No Life Poster Join Date: Nov 2001 Location: England Age: 41
Member: 7653 Status: Offline Thanks Meter: 823 | get rolis tool 1.9 or eeprom tools 3.2 from http://napalm.all.at/ dont need sim card, or instructions.. just look in the software then press the button |
07-31-2003, 03:44 | #8 (permalink) | |
Member: 35839 Status: Offline Thanks Meter: 0 | Quote:
It isn't as simple as buying the cable, downloading the software and period. I went ahead and purchased a Nokia the RS-232 (DLR-3P) data cable. However, when I pluged it into the COM 1 port to an old Windows 98 PC it didn't work. I tried it at my mother in law's XP PC which also had a serial port and it also didn't work. I went ahead and downloaded Nokia Tool Ver 1.8 and the error I got was: Failed to initialyze Local Mode Check MBUS Cable Any ideas or suggestions ????! Maybe I have the wrong cable? Phew.. | |
Pls. Help me unlock my Nokia 6260 | p13rc3 | Phone Unlocking Codes & Maps | 3 | 07-17-2013 15:07 |
RE: Help me unlock my Nokia 3650 | -White-Knight- | WD2 & APE (Symbian Phones) | 8 | 10-05-2004 17:12 |
can someone plz help me unlock my nokia 3650 | 69enforcer | Phone Unlocking Codes & Maps | 2 | 09-18-2003 21:17 |
HELP ME UNLOCK MY NOKIA 5110 & 6310i PLEASE!! | BISCUIT8337 | Phone Unlocking Codes & Maps | 13 | 07-27-2003 02:03 |
Help me Unlock my nokia 3650 | ehab1985 | WD2 & APE (Symbian Phones) | 4 | 07-10-2003 14:44 |
