02-19-2002, 13:14 | #1 (permalink) |
Freak Poster Join Date: Jan 2002 Location: London, UK Age: 49
Member: 8336 Status: Offline Thanks Meter: 3 | I cant unlock 3310 v5.11....please help <br />I have got this 3310 with version 5.11 on it. I tried unlocking it with the correct partials but still its locked. Ok. Before I started,it had Lock 1 & lock 2 locked. I then unlocked it with Rolis 4.77, which it did. Then I put FFFFF in Lock 1 and FFFF in Lock 2 and tried pressing close button in NokiaTool035 but 'Can't Close LocK'. I did not press OK. Quickly swtiched the phone OFF. Then, I relocked it via dejan with the original Partial. Now, The lock 1 = FFFFF and Lock 2 = FFFF BUT, still it only works on one2one only......nothing else. It supposed to be unlocked now but why only accept one SIM type only??? Can someone tell me what I amdoing wrong Please. Thanks. Take Care BR Yasser |
02-19-2002, 13:50 | #2 (permalink) |
No Life Poster Join Date: Mar 2001 Location: Leiria, PT & *******, CN
Member: 3756 Status: Offline Thanks Meter: 5 | Hi! That is weird...<br />I think i have heard around that UK phones with 2nd lock closed, that solution does not work...<br />Prehaps instead of F's you have to put something else? Just try... i guess you've got nothing to loose... <img src="smile.gif" border="0"> Cheers. [ 19 February 2002: Message edited by: [MoOkIe] ]</p> |
02-19-2002, 15:03 | #3 (permalink) |
Member: 8336 Status: Offline Thanks Meter: 3 | Hi Again!!! Yes, in UK Lock 1 and Lock 2 are closed. I triedunlocking my 3310 v5.11 somany times with different tehniques but still no luck. Firstly, there are 2 types of partials on net. One is 64kb and the other is 128 Kb. I think, in my case I use 128 kb. Itried it but no luck. Lock 1 is locked to FFFFF. Lock 2 is locked to 0000 now and before I tried it on FFFF. I have tried using NokiaTool035 and also Winlock but nothing. In the end, I have a phone with Lock 1 now relocked to FFFFF and Lock 2 locked to 0000.......but its NOT unlocked....only works on 1 network...thats one2one. I have also noticed, that each time i unlock it, it works on a different network....very strange. Can someone plz help me to sort this out, so it becomes SIMFREE....or do I have to downgrade to v4.45. Thanks alot. BR Yasser. <img src="smile.gif" border="0"> |
02-19-2002, 15:10 | #4 (permalink) |
Member: 3756 Status: Offline Thanks Meter: 5 | Hi! Just go ahead and downgrade the phone to 4.45... If you are all out of solutions... You only need flasher cable, since FAID is free now... Cheers. |
02-19-2002, 16:09 | #5 (permalink) |
No Life Poster Join Date: Sep 2001 Location: London, UK
Member: 6486 Status: Offline Sonork: 100.79846 Thanks Meter: 350 | hi... downgrade that and than unlock <img src="smile.gif" border="0"> )100% working <br />best regards<br />gohar <img src="wink.gif" border="0"> <img src="tongue.gif" border="0"> |
02-19-2002, 21:22 | #6 (permalink) |
Freak Poster Join Date: Feb 2001 Location: UA
Member: 3309 Status: Offline Thanks Meter: 2 | Use this solution <a href="http://www.schwantz.hpg.ig.com.br/solution.htm" target="_blank">http://www.schwantz.hpg.ig.com.br/solution.htm</a><br />Work 100% ( I have unlocked 5.11 ver )<br />But you necessary to remember one important detail - after relock to FFFFF you necessary to switch OFF and once again switch ON your telephone ( you have for this 15-20 seconds )<br />And flash use "orig...fls" ( start adress 2700000 for unlock.fls too )<br />I unlock phone after the second attempt!<br />Best regards,<br /> Vadim <img src="smile.gif" border="0"> |
i900 omnia cant unlock after flash firmware, please help! | chhay | UST Pro II | 0 | 11-16-2009 04:49 |
2630c cant` unlock with cyclone box please help | hajji1 | Cyclonebox | 5 | 09-16-2009 10:29 |
3310 v5.11 unlockng partials needed | welly2000 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 01-24-2002 01:35 |
8850 v5.11 please help ? | hungpd | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 08-14-2000 14:05 |
