LIGHT REMAINS ON . IS MY 3210 BROKEN? WHEN I PUT THE BATTERY ONTO MY 3210 THE LIGHTS REMAIN ON, ONLY GO OFF WHEN I REMOVE BATTERY |
The phone work after incert the battery ? Or just light is ON ? |
hello m8 try to check the background light control ic , it may be damaged or some water on it . kind regards . |
you dont see anything!!!! when the battery is attached the light comes on immiddiately, without me switching it on.<br />i will open it up and check for water damage |
hello m8 <br />if the mobile is not water damaged , then ur problem is very easy change the on / off<br />switch hope this can help . kind regards . |
hi, as far I remember it can be solved soldering a bridge between two pins of the controler,<br />so easy to repair, best regards,<br />Invisible |
