04-10-2002, 06:58 | #3 (permalink) |
No Life Poster Join Date: May 2001 Location: U.K Age: 54
Member: 4611 Status: Offline Thanks Meter: 68 | Thanks for that, but like I said it is not the screen, or the screen connector. it is not a bad connection between the main board and the screen. I have also had the board in an ultrasonic bath for an hour, and the fault is still there. Any other ideas anyone |
04-10-2002, 07:30 | #4 (permalink) |
Junior Member Join Date: Dec 2001 Location: Nottingham
Member: 8095 Status: Offline Thanks Meter: 0 | Lines missing I have seen this before. Unfortunately, i didn't have time to look at this phone. I suggest you get another 33xx to compare continuity and check for broken tracks on the LCD pads. Also check BGA chips for dry joints (reflow BGA's if you can). Not sure but this could also be linked to LCD. The one i saw with the same problem you have had also been in ultra sonic tank. must have had water damage. |
04-10-2002, 19:26 | #6 (permalink) |
Insane Poster Join Date: Dec 2000 Location: UK
Member: 2830 Status: Offline Thanks Meter: 0 | Hi, I had same problem with a 3330, problem solved by changing screen for one made by different manufacturer ( I think that nokia use screen from 2/3 different manufacturers (philips etc) on 3310/3330. You can tell difference by looking at connector. Regards max |
04-14-2002, 04:16 | #8 (permalink) |
Junior Member Join Date: Aug 2001 Location: PL
Member: 5803 Status: Offline Thanks Meter: 0 | first check connections between capacitors and lcd pad more here : http://forum.gsmhosting.com/vbb/show...threadid=27147 |
05-06-2002, 14:50 | #10 (permalink) |
Freak Poster Join Date: Mar 2002 Location: Chester UK
Member: 10048 Status: Offline Thanks Meter: 3 | @blartiarfast your first post said (not elastomer) i have changed dozens of 33xx displays but never seen one with an elastomer, all the ones i see have contacts (pin type) so changing the lcd does seem like a possibility. |
05-06-2002, 19:58 | #11 (permalink) |
Member: 4611 Status: Offline Thanks Meter: 68 | Sorry for any confusion, but when I said elastomer, I just meant the connector between the screen and the mainboard. I said this in an attempt to cut down useful replies to the fault requested that I have already tested |
05-07-2002, 07:28 | #13 (permalink) |
No Life Poster Join Date: Oct 2001 Location: -------- Age: 55
Member: 7062 Status: Offline Thanks Meter: 126 | don't try another solution :) Check connection betwen C413 and C409 to 1 pin LCD and C410 and 412 to 7 pin LCD If no connection -alternate lines Check PCB near capacitors |
Rx2 and vpp button missing on my setup | luyanda | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 5 | 03-29-2010 16:07 |
repair lines missing on display | noname1 | Nokia Hardware & Hardware Repair | 0 | 11-02-2004 00:00 |
HOW TO ACTIVATE 2ND LINE ON 3310 | rigby | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 02-01-2002 03:40 |
menu missing on 3310 | Neo's | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-23-2001 07:31 |
missing menus on 3310 | reo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 04-24-2001 02:19 |
