01-26-2002, 10:08 | #1 (permalink) |
Crazy Poster Join Date: Feb 2001 Location: Manila, Philippines
Member: 3367 Status: Offline Thanks Meter: 0 | Need to open lock 4 of 3310 v4.45!! Help! Lock 1: 51503 Closed (Smart Telecommunications)<br />Lock 2: 0000 Open<br />Lock 3: 0000 Open<br />Lock 4: 000FFFFFFF Closed I need to open only lock4 because he wants to preserve lock 1 for warranty purposes. Any ideas on how to do it? I tried solution at gsmschwantz but it doesn not work. I also tried opening using 3310v445 fls, close lock one using nokia tool without pressing "ok" button, then reflashing original fls but phone still relocks itself to 1 and 4. Any suggestions please? I'm desperate!!! |
01-26-2002, 10:14 | #2 (permalink) |
VIP-Member Join Date: Jun 1999 Location: Athens, Greece
Member: 254 Status: Offline Thanks Meter: 7 | Hello philkho<br />I thing your problem is not so big to panic you <img src="smile.gif" border="0"> <br />I have the same problem is the past and I solved 100 , following these instructions i found in old topics in our forum.<br />Read and do the followings.<br /><br />For Lock 1 & 4 <br />If your phone is locked by lock 4 or lock 1+4 you need a other solution. <br />If you use only the nokiatool to relock it will not work.<br />So the member "jan" has a great idea to solve this problem.<br />First read original partial flash from 28-29 or 29-2A like i explain it above. <br />Than open locks with unlocked partial.<br />Use the cracked Winlock 1.10 soft and press read phone.<br />Than fill the fields at lock 1 and lock 4 with "????...", set lock 1 and lock 4 to close and press the "Close SimLocks" bottom.<br />Than flash back the original partial. Your phone is now relocked to lock 1 and lock 4 with "FFFF..." and works 100% fine!! Good luck <br />Robby |
01-27-2002, 19:01 | #5 (permalink) |
No Life Poster Join Date: Mar 2001 Location: Leiria, PT & *******, CN
Member: 3756 Status: Offline Thanks Meter: 5 | [quote]Originally posted by philkho:<br /><strong>Tried that. IT doesn't work. Phone reverts back to lock 1 and 4 as stated on my 1st post.</strong><hr></blockquote> Hi! If you want to unlock and then re-lock it again... then use the following.... i think this will help you... I presume you have a flasher cable??? (You need both flasher and MBUS cables...) i strongly suggest you make a backup... 1st- read flash as it is right now, adr: 00280000 to 00290000... save it to secure location... size is 64kbs 2nd- write patched (unlocked) parcial to phone, adrs: 00280000; 3rd- open winlock and in 1st lock put "51503"... <br />and in 4th lock put ?????? in it and press close simlocks....; 4th- flash original partial back to the phone... the one you did in step 1... That should do it... but you will have 1+4 lock closed in phone... but 4th lock is the same has beeing unlocked because it will accept any sim card from Smart Telecommunications... Hope this will help you.<br />C ya! |
Need To Open 4 locks in 3310 | Egypt Unlocker | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 12 | 12-04-2001 18:28 |
Need 3310 v4.45 full flash please | gamalabel | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 10-25-2001 18:16 |
made back up on 3310 v4.45... 4 locks closed?!?! | trafix | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 09-24-2001 09:06 |
Help!!! needed 3310 v4.45 unlock fls. | Rex | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 07-11-2001 17:02 |
How to unlock lock 4 of 3110? | 1aitunon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-04-2001 20:44 |
