07-31-2001, 17:34 | #1 (permalink) |
No Life Poster Join Date: Jun 2001 Location: London Age: 41
Member: 5006 Status: Offline Thanks Meter: 2 | Nokia 8210 lcd replacement. Please give me directions and tips on replacing the new one, or do i have to buy the metal casing as well, and how easy it is to fit the new lcd on It is for the Nokia 8210. |
07-31-2001, 18:01 | #2 (permalink) |
Freak Poster Join Date: Jun 2000 Location: laguna,philippines Age: 48
Member: 1544 Status: Offline Thanks Meter: 1 | here goes... remove the four screws on the phone then separate the pcb to the metal holder of the lcd with the keypad membrane , these two halves are jointed by the 2 clips on each side of the phone.... now on the lcd plate... u can see 5 plastic rivets... 4 above the lcd and 1 near the speaker... remove them by sidecutter or blades... next there are 4 clips 2 on each side of the lcd.... these can be easily removed with ur nails.... after removing them... u can now liftthe metal part from the plasic part.. remove the lcd and replace it.... after that secure the clips again on both side... slightly lift the contacts of the speakers to asure it will touch the pcb.... check if the backup battery is in place..... goodluck... |
Need help with Nokia 6303c LCD replacement | Eeyorre | Nokia Hardware & Hardware Repair | 4 | 09-24-2010 08:53 |
Nokia 3250 LCD Replacement | bbmad | Nokia Hardware & Hardware Repair | 0 | 08-17-2006 18:19 |
nokia 7710 lcd replacement screen | sweetmestiza23 | Hardware Repair Item Wanted | 1 | 03-06-2006 18:26 |
nokia 8210 lcd just dark screen | hooi76 | Nokia Hardware & Hardware Repair | 3 | 05-15-2005 05:21 |
Brand New Nokia 8210 LCDs with Frames £8.50 each | logosunlimited | Main Sales Section | 7 | 12-08-2001 20:24 |
