03-29-2003, 01:34 | #1 (permalink) |
Freak Poster Join Date: Jan 2001 Location: Uzhgorod, Ukraine Age: 47
Member: 3023 Status: Offline Thanks Meter: 1 | Using Griffin for DCT3 flashing. Finally I made my Griffin to work with most DCT3 phones. As for hardware, there are two mistakes in all three cable schemes found on support page (two PDF documents): connection for pin 3 of RJ-45 connector should be swapped with pin 7, and pin 4 with pin 6 as well. For correct wiring consult this pinout of Griffin box (numbered from left to right, looking from the front of the cable, and the locking latch is up): 1 - Vcc 2 - nc 3 - BSI (AFAIK for DCT3 it used as BTEMP to power up the phone) 4 - TX 5 - RX 6 - MBUS 7 - GND 8 - Vpp (not used in DCT3 cables) (thanx gsm-tech for this info) As for software part, in each folder with flashes for DCT3 models you should have an INI file. For those of us, who allready have a relatively large archive with DCT3 flashes in different format and don't willing to download them again in original Nokia packages just to get those INIs, I'll tell how to create them manually. But first a few words about flash files. You'll need them in WinTesla format, so to convert from Dejan 1.05 you will need to cut off first 16 (decimal) bytes of PPM to get plain binary and then convert by dejan2wt tool by Lead. In the INI file itself the Griffin seems to look only for three lines which are as follows: [NSM-1_RESTOREFILES] LowEraseLimit=200000 HighEraseLimit=3FFFFF The first one is the model definition (don't know if the INI file name should be same as model type, but the line 1 should match exactly. The second is the flash start address and it should be 200000 for all DCT3. The last one is a bit tricky. You can count this as 200000h+MCU_size+PPM_size or as 200000h+Flash_chip_size-EEPROM_area_size. In most cases you'll get equal results, but if not, make sure Griffin won't overwrite any vital data (it WILL erase the whole area specified regardless of real MCU and PPM size). For old models with external EEPROM you should specify the whole flash chip. Models with JAVA contents (e.g. 3410) are still under question: should it overwrite JAVA or not? Here are addresses I calculated: 3210 NSE-8 3FFFFF NSE-9 3FFFFF 3310 NHM-5 3CFFFF 3330 NHM-6 54FFFF 5110 NSE-1 2FFFFF 5130 NSK-1 2FFFFF 5510 NPM-5 54FFFF 6110 NSE-3 2FFFFF 6130 NSK-3 2FFFFF 6150 NSM-1 3FFFFF 6210 NPE-3 59FFFF 6250 NHM-3 59FFFF 7110 NSE-5 58FFFF 8210 NSM-3 3CFFFF 8250 NSM-3D 3CFFFF 8810 NSE-6 3FFFFF 8850 NSM-2 3CFFFF 8890 NSB-6 3CFFFF 3410 NHM-2 56FFFF 5210 NSM-5 57FFFF 3610 NAM-1 54FFFF 2100 NAM-2 3FBFFF Please, correct me if I'm wrong. So, for example for 3310 you should make a folder NHM-5 inside PRODUCTS folder, copy your WinTesla flashes there, then make a text file NHM-5.ini with following text inside: [NHM-5_RESTOREFILES] LowEraseLimit=200000 HighEraseLimit=3CFFFF Questions, that are still open, are: 1. There are no cable scheme for 3210 and 8810, and since the first one uses 2.4v battery and uses VPP for flashing, don't know how to make cable for it. 2. What End address should be specified for Java enabled phones. |
Don't use Griffin for flashing BB5 | hanen | Griffin | 6 | 10-14-2005 09:38 |
Cant Use Griffin for flashing DCT3 & DCTL | Molly | Griffin | 1 | 04-25-2005 22:13 |
Here is solution for uploading DCT3 Eprom using griffin | MAK_US1977 | Griffin | 30 | 09-13-2004 09:27 |
Using Griffin for 5210 | khansa | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 08-01-2003 14:20 |
