Nokia Digital Core Technology 4 ( DCT-4 ) DCT-4 Phones: 1100 , 1100 , 1101 , 1108 , 1110 , 1110 , 1110i , 1112 , 1112 , 1112i , 12i GSM Modul, 1600 , 1600 , 2112 , 2125i , 2126i , 2128i , 2255 , 2300 , 2300 , 2355 , 2600 , 2650 , 2651 , 2652 , 2760 Americas, 2760 Europe/Asia, 30 Terminal, 3100 , 3105 , 3108 , 3120 , 3120 , 3125 , 3128 , 3129 , 3152 , 3155 , 3155i , 3200 , 3205 , 3205i , 3220 , 3220 , 3300 , 3300 , 3320 , 3321 , 3360 , 3361 , 3510 , 3510i , 3520 , 3530 , 3560 , 3570 , 3585 , 3586 , 3586i , 3587 , 3587i , 3588i , 3589i , 3590 , 3595 , 3595i , 5070 , 5070 , 5100 , 5140 , 5140 , 5140i , 6010 , 6012 , 6015 , 6015i , 6016i , 6019i , 6020 , 6020 , 6021 , 6030 , 6030 , 6050 , 6060 , 6060 , 6061 , 6070 , 6070 , 6080 , 6080 , 610 Car Kit, 6100 , 6101 , 6101 , 6101 , 6102 , 6102 , 6102 , 6102 , 6103 , 6103 , 6108 , 6111 , 6112 , 6152 , 6155 , 6155i , 616 Car Kit, 6170 (TIKU) , 6170 (TIKU) , 6200 , 6220 , 6225 , 6225i , 6230 (TIKU) , 6230 (TIKU) , 6230i (TIKU) , 6235 (TIKU) , 6235i (TIKU) , 6236i , 6255 (TIKU) , 6255i (TIKU) , 6256 , 6256i , 6310 , 6310i , 6340 , 6340i , 6360 , 6370 , 6385 , 6500 , 6510 , 6560 , 6585 , 6590 , 6590i , 6610 , 6610i , 6650 , 6651 , 6800 , 6800 , 6810 , 6820 , 6820 , 6820i , 6822 , 6822 , 7200 , 7210 , 7250 , 7250i , 7260 , 7270 (TIKU), 7270 (TIKU) , 7280 (TIKU) , 7280 (TIKU) , 7360 , 7380 , 7600 (TIKU) , 7620 , 810 Car Kit, 8310 , 8390 , 8587 , 8800 (TIKU) , 8800 Sirocco Edition (TIKU) , 8801 (TIKU) , 8910 , 8910i , D211 , Nokia Remote Camera DCT-4+ (Plus) : 1200 , 1208 , 1208b , 1209 , 1650 , 1650b , 1680c-2b Classic, 2310 , 2600c , 2610 , 2610b , 2626 , 2630 Americas, 2630 Europe/Asia, 2670h Fold, 5000 , 5000 , 7070 |
02-13-2003, 19:00 | #1 (permalink) |
No Life Poster Join Date: Apr 2002 Location: The Green Mile
Member: 11325 Status: Offline Thanks Meter: 266 | Need help on Griffin schema about 2 resistors after power connector must they be low power or it does not matter? thanks a lot al |
02-13-2003, 19:27 | #3 (permalink) |
Member: 11325 Status: Offline Thanks Meter: 266 | well i am ashamed to tell this but these resistors for some reason eh...... literally burnt up. I never had such a thing happen. i take care for the equipment. Hope to replace them and maybe fix the box once and for all. At least i must say that the producers ofthe griffin box did the box in a maintainable way. Well done for the design. thanks for the help al |
02-13-2003, 21:44 | #4 (permalink) |
Member: 11325 Status: Offline Thanks Meter: 266 | changed them and also a ****n up diode IN535 it is powering up ok however it is failing to flash. It is recognising phones now and can power up the phones ok eh. seems need more trouble shooting. al |
02-14-2003, 15:59 | #6 (permalink) |
Freak Poster Join Date: Dec 2001 Location: Hong Kong, China
Member: 7866 Status: Offline Thanks Meter: 4 | Have already told you cannot supply high voltage to Griffin Box, you will 'Burn' the box, those 2 resistors are 2 Ohm. If you have already replaced the resistor but the Box still not work, that means, you have also 'burned' other components. There has no 67K Ohm resistor inside Griffin Box !!!! Cables [email protected] |
02-14-2003, 20:56 | #7 (permalink) |
Member: 11325 Status: Offline Thanks Meter: 266 | mates it is powering up ok but i have a ****n up diode i cant figure out what it is... it is near the power onnetor too.. a BIG black diode. 1N535X the X is from 0 to 9. Anyone can check pls? I changed it with notehr diode but it is incorret. It can recognise phones ok but nat flash them . Thanks for the help and support al |
02-15-2003, 09:49 | #8 (permalink) |
No Life Poster Join Date: Apr 2002 Location: Radiometer Medical ApSBrønshøj Age: 51
Member: 10854 Status: Offline Sonork: 1578988 Thanks Meter: 3 | Hiya This was misunderstanding....I was speaking about 2 resistors in dummy battery for dct4. Both of them 67kOhm and simulating battery temp. BR Vule |
02-15-2003, 11:38 | #9 (permalink) |
Member: 7866 Status: Offline Thanks Meter: 4 | It is 1N5350, I have said, may be another components was damaged in your Box, not only these two 2 Ohm resistors and this 1N5350 !!!! If you have some basic electronics skill, you should know what's the purpose of this 'Diode'... Even you don't replace (or without) this 1N5350, the Griffin Box can work for both unlocking and flashing if there are no other faulty components !!!! Cables [email protected] Last edited by Cables; 02-15-2003 at 11:44. |
02-15-2003, 19:42 | #10 (permalink) |
Member: 11325 Status: Offline Thanks Meter: 266 | Thanks for the reply cables I am trying to fix it so as to avoid sending it back. At first it did not even detect phones at all. As it is it is detecting them. I tried to contact you via ICQ mate but had no reply. al |
