Nokia 6230 "Camera Operation Failed" Hi I have a Nokia 6230, which has a problem with the camera. I have removed the memory card from the phone and when i go to camera it comes up with the following message: "Operation Failed, Memory full delete items from Gallery" There are no items in the gallery and i have also formated the memory. If i insert the memory card into the phone, it still comes up with the same message but when i change its location to the memory card, then camera will work. Any Ideas?? |
flash the phone it will be ok i am test seem problem |
Try a full reset of the phone. |
ive the same problem with version 4.24 and i flashed the phone with version 4.44 but the same .. ''Operation Failed, Memory full delete items from Gallery'' then .. i put Full Factory Reset .. and nothing change .. i think that the problem is in a circuit .. can anybody confirm this question ? thanks in advance |
hi need format user area br |
What do you mean bro?? |
flasher 4.44 and formatuser area then |
pls use RH-12_dp_v_147.0_mcusw05.26.exe ,when flasher this ver. have not problem.pls try. then post the result here! BR |
change camara it self good work |
yeah that is all........... |
No need to change camera. I had the same problem. Make full reset in Griffin, will be ok. (If not , format user area). |
change soft v5,24 and change good PM I have the same problem ,now its OK |
try to format drive using jaf or prodigy. if it failed, you have problem with the flash ic. Check it using tornado, twister (any saras soft) and see if software can read the second flash ic.... :D |
do not need to change ur camera pls use griffin for format user area , u get ur problem solved. |
tried format format failed |
