02-04-2004, 04:44 | #1 (permalink) |
No Life Poster Join Date: Apr 2001 Location: Sun Age: 44
Member: 4021 Status: Offline Thanks Meter: 782 | 1100 charging problem is it the uem??? or its somewhere else.. we checked the lines, the connections but seems ok.... pls help me.. tnx!!!!!!! |
02-04-2004, 07:32 | #2 (permalink) |
Freak Poster Join Date: Jul 2002 Location: MAD Age: 50
Member: 13545 Status: Offline Thanks Meter: 2 | check VCHAR at L100 is 2.1 VDC ...? if not u must check the fuse F100, and also check L100,V100,C100,R200, but do not forget to check the connector Good Luck ------------- MrHazeem |
02-05-2004, 17:40 | #5 (permalink) |
Freak Poster Join Date: Aug 2003 Age: 49
Member: 37060 Status: Offline Thanks Meter: 6 | please u have digram for this please send me on mail pleaseeeeeeeee my mail [email protected] thanx in advance dan21 |
04-27-2004, 14:23 | #7 (permalink) |
No Life Poster Join Date: Sep 2000 Location: Turkey Age: 43
Member: 2088 Status: Offline Sonork: 100.1630154 Thanks Meter: 57 | Problem is found.. ( d200 or d400 -> cpu or uem ) are damaged. but they are both glued .. I dont know what nokia repair center makes these boards |
07-15-2004, 12:34 | #13 (permalink) | |
No Life Poster Join Date: Sep 2002 Location: India
Member: 15238 Status: Offline Thanks Meter: 128 | Quote:
A nok1100 - except charging everything was OK. Software ! no success. I tried to replace the part shown in pic attached. But again no success. Then i simply short that two points.. and everything was OK.. u can try this. | |
The Following 2 Users Say Thank You to i_seeque For This Useful Post: |
07-21-2004, 20:47 | #14 (permalink) |
No Life Poster Join Date: Nov 2002 Location: Everywere Age: 46
Member: 18057 Status: Offline Thanks Meter: 64 | @ i_seeque here i have 1100 hot prob... any idea like your change r100 . any modifications ?? pls.... reply here i have lots of phones. pls...... b.r. akki |
07-24-2004, 10:26 | #15 (permalink) |
No Life Poster Join Date: Apr 2003 Location: Greece Age: 47
Member: 26279 Status: Offline Thanks Meter: 274 | @all the R100 on the picture is the solution for 1100 charging problem. BUT THIS IS NOT THE FUSE AND DONT CONNECT WITH WIRE THIS 2 POINT'S as the picture write.this is 47Kohm THERMAL resistor and is the bat temperature sensor.so to work just put 47k thermal resistor or simple resitor(in second case you will not have over temperature protection). i'm more than 1000% that this problem became after flashing because one type of cable removing this resistor when you try to connect it. |
nokia 1100 charging problem | patric | Nokia Hardware & Hardware Repair | 7 | 09-24-2009 18:19 |
1100 charging problem | avtar | Nokia Hardware & Hardware Repair | 37 | 07-16-2008 08:41 |
1100 charging problem | jawad8305 | Nokia Hardware & Hardware Repair | 1 | 06-25-2007 08:43 |
Nokia 1100 Charging problems | ebendup | Nokia Hardware & Hardware Repair | 2 | 06-27-2006 08:15 |
1100 Charging problem | nutantopno | Nokia Digital Core Technology 4 ( DCT-4 ) | 6 | 04-16-2006 16:33 |
