1100 Hang Nokia & Restart :(1100 Hang Nokia & Restart Plzz Helpp |
try to flash with highest version |
did flash with rh18_08.110 butt same problem plz helpp |
ok if u have original battary and ur lcd original and same problem goto heat ur flach ic but becarfully |
re: Quote:
Yeah.... its d common problem of 1100,2300,2600 fones though UPP & UEM r sealed after longtime of usage so its Harware problem mate & its really risky to remove 1 of those components,practice is required. |
just a suggestion. why don't u try to erase full flash with ufs? after that don't make ui setting. write pm first, init sim lock. then u can make ui setting. if not working then u have hardware problem. chek batt conn, sim conn, and use original batt. :D |
change the software version ........................................ |
reball or change flash ic & check because 20 days ago I already repair a 1100 same like your post result |
thankss to all off uu....after read & right pm my problem is solveed...thankkss for urs valuable guideance.. |
hi brother re ball flsh ic |
I advise u to practice removing sealed Uem,UPP as possible as u can coz time will come u will encounter hardware problem & its ur chance to do it alone. :cool: |
try to flash with last version |
@zahed1978 @shiju Problem has been solved. see post #10 |
reball or change flash ic & check because 30 days ago I already repair a 1100 same like your .............. |
