03-13-2010, 17:31 | #1 (permalink) |
No Life Poster Join Date: Mar 2005 Location: United Arab Emirates Age: 43
Member: 130244 Status: Offline Sonork: 100.1609062 Thanks Meter: 143 | 1110 after sim ic change show CS solution 1- remove sim ic make jumpers show contat service 2- make some heat on upp with glow and clean the board problem not solve 3- i change 3 lcd of same 1110 bt same problem contact service 4- i change 1110 lcd with 1112 and set is perfect ok every thing ok 5- now i check 3 1112 lcd all r ok n set is working perfect 6- again i put 1110 lcd which come with set and set is now working with its own lcd and no problem... please check this solution after changing sim ic set show contact service. i check it on RH70 1110. |
03-13-2010, 19:13 | #2 (permalink) |
Moderator Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | full flash your set with jaf then check |
The Following User Says Thank You to .:SARCAR:. For This Useful Post: |
07-09-2010, 05:56 | #5 (permalink) | |
Freak Poster Join Date: Apr 2007
Member: 494019 Status: Offline Thanks Meter: 159 | nokia 1110 Quote:
1208 after sim ic jumpers charging not shows | shoukat2003 | Nokia Hardware & Hardware Repair | 4 | 10-12-2009 06:47 |
3110 After sucessful flash phone show CS problem | amol_sm | J.A.F. By Jafsupport.com | 1 | 11-04-2008 12:56 |
1110 2310 sim ic sim tray ke jumper | suresh_boy04 | Nokia Hardware & Hardware Repair | 1 | 07-03-2008 14:41 |
1110 insert sim can i try this solution??? urgent | sallu | Nokia Hardware & Hardware Repair | 1 | 03-25-2006 15:26 |
8210 no network after MAD2 IC changed | Chaku | Nokia Hardware & Hardware Repair | 6 | 11-12-2001 23:22 |
