07-27-2007, 08:01 | #1 (permalink) |
Freak Poster Join Date: May 2007 Location: phillipines
Member: 508598 Status: Offline Thanks Meter: 11 | 1110i no power after finish the flash what is the problem??????? JAF version 1.98.9 Detected PKEY: 90007C51 Card life counter: 99.60% P-key nokia module version 01.00 Detected JAF INTERFACE version: 01.AC, Driver version: 0, Library version: 30107 JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\ FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\products\rh-93\rh93_06.000 PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\products\rh-93\rh93_06.000 PPM Flash file: C:\Program Files\Nokia\Phoenix\products\rh-93\rh93_06.00aa CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,Dannish,Norwegian,Swedish Backing up PM Field 208 as RPL... Setting local mode... Failed! Aborting! Failed to backup imei... MCU: C:\Program Files\Nokia\Phoenix\products\rh-93\rh93_06.000 Booting phone... Phone didn't answer with TX line high after power on! Causes: 1. Phone don't power on -> Check cable 2. TX pin from phone don't make contact -> Check cable 3. UPP damaged -> change UPP MCU ID: 0xAAAA This MCU ID is not supported in chosen flash file... Error booting phone... Backing up PM Field 208 as RPL... Setting local mode... Failed! Aborting! Failed to backup imei... MCU: C:\Program Files\Nokia\Phoenix\products\rh-93\rh93_06.000 Booting phone... MCU ID: 0x2201 BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia Loader version: 04.3B.00 -> Revision: 0007 Boot size is 0x0958 Boot is ready... FLASH ID0: 00EC2268 -> ST Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00000001 -> NOT USED Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x6822EC00 Flash loader is C:\Program Files\ODEON\JAF\Flash\u_amd.fia Loader version: 04.3B.00 -> Revision: 0007 Loader size is 0x6F48; Loader chk: 26 Loader is ready... P-key nokia module version 01.00 MSID: 84A99BE5A48029ED203BC41440 MSID decoded: 3E4EBAE900551D61AA000000 FAID: 2419FDAA4A275C6175FCB9BF Operation took 0 minutes 17 seconds... Erasing... Found 5 interval(s) to erase Erasing area: 01000000 - 0100FFFF... Erasing area: 01010000 - 013BFFFF... Erasing area: 013C0000 - 013EFFFF... Erasing area: 017C0000 - 017EFFFF... Erasing area: 01FC0000 - 01FEFFFF... Operation took 0 minutes 23 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 12 seconds... Restarting MCU... PPM: C:\Program Files\Nokia\Phoenix\products\rh-93\rh93_06.00aa Booting phone... MCU ID: 0x2201 BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia Loader version: 04.3B.00 -> Revision: 0007 Boot size is 0x0958 Boot is ready... FLASH ID0: 00EC2268 -> ST Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00000001 -> NOT USED Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x6822EC00 Flash loader is C:\Program Files\ODEON\JAF\Flash\u_amd.fia Loader version: 04.3B.00 -> Revision: 0007 Loader size is 0x6F48; Loader chk: 26 Loader is ready... P-key nokia module version 01.00 MSID: 84887C8D15643B84E0C31C19C3 MSID decoded: 3E4EBAE900551D61A9000000 FAID: E641DB018402283AE39E48BA Operation took 0 minutes 16 seconds... Erasing PPM... Found 2 interval(s) to erase Erasing area: 011E0000 - 011EFFFF... Erasing area: 011F0000 - 0137FFFF... Operation took 0 minutes 10 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 9 seconds... Restarting MCU... Flashing Done! Operation took 1 minutes 58 seconds... After flash processing... Waiting for phone to boot... Reading... Phone type: RH-93, Software version: 6.00 IMEI: 354540010617261 Product Code: 0537104 Resetting PPC... Done! Backup IMEI zone... Setting local mode... Reading IMEI... Reading IMEI data... IMEI data corrupt... Getting MCUID... MCU ID: 0x2201 Reading flash chip detailes... FLASH ID0: 00EC2268 -> ST Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00000001 -> NOT USED Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 MCU ID: 0x2201 Boot is ready... Algo is ready... Loader is ready... Erasing area: 01000000 - 01FFFFFF... Done! Backing up PM Field 208 as RPL... Setting local mode... Failed! Aborting! Failed to backup imei... MCU: C:\Program Files\Nokia\Phoenix\products\rh-93\rh93_06.000 Booting phone... MCU ID: 0x2201 BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia Loader version: 04.3B.00 -> Revision: 0007 Boot size is 0x0958 Boot is ready... FLASH ID0: 00EC2268 -> ST Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00000001 -> NOT USED Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Flash ID is 0x6822EC00 Flash loader is C:\Program Files\ODEON\JAF\Flash\u_amd.fia Loader version: 04.3B.00 -> Revision: 0007 Loader size is 0x6F48; Loader chk: 26 Loader is ready... P-key nokia module version 01.00 MSID: 84A99BE5A48029ED203BC41440 MSID decoded: 3E4EBAE900551D61AA000000 FAID: 2419FDAA4A275C6175FCB9BF Operation took 0 minutes 16 seconds... Erasing... Found 5 interval(s) to erase Erasing area: 01000000 - 0100FFFF... Erasing area: 01010000 - 013BFFFF... Erasing area: 013C0000 - 013EFFFF... Erasing area: 017C0000 - 017EFFFF... Erasing area: 01FC0000 - 01FEFFFF... Operation took 0 minutes 23 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 12 seconds... Restarting MCU... PPM: C:\Program Files\Nokia\Phoenix\products\rh-93\rh93_06.00aa Booting phone... MCU ID: 0x2201 BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia Loader version: 04.3B.00 -> Revision: 0007 Boot size is 0x0958 Boot is ready... FLASH ID0: 00EC2268 -> ST Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00000001 -> NOT USED Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x6822EC00 Flash loader is C:\Program Files\ODEON\JAF\Flash\u_amd.fia Loader version: 04.3B.00 -> Revision: 0007 Loader size is 0x6F48; Loader chk: 26 Loader is ready... P-key nokia module version 01.00 MSID: 84887C8D15643B84E0C31C19C3 MSID decoded: 3E4EBAE900551D61A9000000 FAID: E641DB018402283AE39E48BA Operation took 0 minutes 16 seconds... Erasing PPM... Found 2 interval(s) to erase Erasing area: 011E0000 - 011EFFFF... Erasing area: 011F0000 - 0137FFFF... Operation took 0 minutes 9 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 8 seconds... Restarting MCU... Flashing Done! Operation took 2 minutes 0 seconds... After flash processing... Waiting for phone to boot... Reading... Phone type: RH-93, Software version: 6.00 IMEI: 354540010617261 Product Code: Resetting PPC... Done! |
t219s no power after trying to flash with nspro | joauz | NSPRO | 5 | 10-04-2009 02:17 |
kg800 no power after changing the charge socket | albion13 | LG Hardware Repair | 0 | 06-05-2009 17:18 |
U have the power but without it u have no power so get the power-----now | unlockingcrew | Main Sales Section | 0 | 11-13-2008 13:27 |
1110i no display after flash | vishal123123 | Nokia Hardware & Hardware Repair | 9 | 07-25-2008 06:46 |
6600 no power after whater damage - flash OK | et.com | Nokia Hardware & Hardware Repair | 3 | 06-29-2005 13:47 |
