Old 03-26-2009, 08:29   #1 (permalink)
Member: 696940
Sonork: 1624473
Thanks Meter: 25
1112 not charging
hello all members
nokia 1112 show not charging i do every thingbut no result
i use these salutions
1.remove 4 legs resister near ringer ic
2.change r22
3.change resister near keypad ic
4.change battry
5.change charger
6.flash set
7.remove capister near battry terminal
8. wash all bord
all result is same not charging
Old 03-26-2009, 08:44   #2 (permalink)
suraj9860607689's Avatar
Member: 787710
Sonork: not using
Thanks Meter: 771
http://rapidshare.com/files/21365310...tmode.JPG.html
Try To uSe This Link Hope u Will Enjoy My SMALL Help...
Old 03-26-2009, 09:03   #3 (permalink)
reaj's Avatar
Member: 631470
Thanks Meter: 163
Try this solution or write cnt file
The Following User Says Thank You to reaj For This Useful Post:
Old 03-26-2009, 17:36   #4 (permalink)
Member: 864178
Thanks Meter: 12
bettary conectors middel socket must be attached wth ground
just remove that shorting i tried it many times
3660 not charging help plz dj.comcell WD2 & APE (Symbian Phones) 0 03-29-2010 14:08
1110-1600-1112 not charging GSMONNITIN Nokia Hardware & Hardware Repair 5 09-19-2008 09:23
1112 not charging muruganssv Nokia Hardware & Hardware Repair 2 05-16-2008 12:38
Nokia 1112 Not charging Naeem Bhatti Nokia Hardware & Hardware Repair 9 10-12-2007 10:40
nokia 1112 not rispons to charge Rishee Nokia Hardware & Hardware Repair 2 03-25-2007 13:42
Page generated in 0.15429 seconds with 9 queries
