03-23-2011, 12:45 | #1 (permalink) |
Major Poster Join Date: Oct 2009 Location: punjab ghogra
Member: 1141035 Status: Offline Sonork: shallysaroya Thanks Meter: 8 | 1208 flashing erore Library version: 1.0.0.9100(23-12-2010), 1.0.0.15151(24-12-2010) ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0089 8872 [Intel 28F320W18,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00535E04A3BDA66 ASIC type: 11 UEM Imei: 35933902389909 Processing MCU file: rh105_05.910 [DCT4,DCT4 ALGORITHM] size: 2.28 MB Supported Ids: 2292 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0089 8872 [Intel 28F320W18,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00535E04:2984DA60 Area [01000000-0100FFFF] erased in 0.578 s Area [01010000-013AFFFF] erased in 33.312 s Area [013B0000-013EFFFF] erased in 2.562 s Area [017C0000-017EFFFF] erased in 0.141 s Area [01FC0000-01FEFFFF] erased in 0.109 s Flash programming ... Programming completed in 22.094 s File Processed in 1 min 7.281 s Processing CNT file: rh1050_nai5.91el [DCT4,DCT4 ALGORITHM] size: 112.21 KB Supported Ids: 2292 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0089 8872 [Intel 28F320W18,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00535E04:2984DA60 Area [01380000-013AFFFF] erased in 1.813 s Flash programming ... Programming completed in 1.172 s Extracting Content Pack, File Server fake reply for CUI phone. Content Pack extracted successfully in 0.594 s File Processed in 18.969 s Processing PPM file: rh105_05.91el [DCT4,DCT4 ALGORITHM] size: 1.05 MB Supported Ids: 2292 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0089 8872 [Intel 28F320W18,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00535E04:2984DA60 Area [01240000-0124FFFF] erased in 0.578 s Area [01250000-0137FFFF] erased in 10.969 s Flash programming ... Programming completed in 10.234 s File Processed in 32.437 s Flashing completed in 2 min 19.938 s Phone Type: RH-105 SW Version: V 5.91 27-03-09 RH-105 (c) NMP Imei plain: 35933902389909-8 Product Code: 0560689 Cellular System: GSM ASIC ID: 0x2292, type: 11 Ppm Id: EL Language Pack: - not available. Imei net: 35933902389909 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 0000000000000000 PROFILE_BITS: 800000000001000B BLOCK 1: 1.CORRUPTED BLOCK 2: 1.CORRUPTED BLOCK 3: 1.CORRUPTED BLOCK 4: 1.CORRUPTED BLOCK 5: 1.CORRUPTED BLOCK 6: 1.CORRUPTED BLOCK 7: 1.CORRUPTED pls help me sir |
The Following User Says Thank You to shallysaroya For This Useful Post: |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
Nokia Flash Content. | Phantom | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-01-2000 23:28 |
