04-27-2009, 05:01 | #1 (permalink) |
Freak Poster Join Date: Apr 2008
Member: 753348 Status: Offline Sonork: no Thanks Meter: 14 | 1208 flashing error but show sim registration failed but i flash the mobie show this message i on the mobile but show contact sevice 1st Boot: Ok, DCT4, UPP: 2292 [Rh-105] [2.0.8.4] 2nd Boot: u3_2nd.fia, Ver: 4.76.0 Fl0: 0x01000000-0x017FFFFF,00898874,Int 28F640W18-T Algorithm: u3_intel.fia, Ver: 4.76.0 Algorithm Ok, MSID: 842D10F896B466DD171335B045 Decoded MSID: 3E4EBAE9-00C8052A-A8000000 Encoded FAID: 6433C39D-5004F625-9A37CFEF IMAGE: rh105_05.710 Area1: 0x01000000-0x0100FFFF Erased, Time: 00:00 Area2: 0x01010000-0x013AFFFF Erased, Time: 00:37 Area3: 0x013B0000-0x013EFFFF Erased, Time: 00:03 Area4: 0x017C0000-0x017EFFFF Erased, Time: 00:02 Area5: 0x01FC0000-0x01FEFFFF Out of Chip Bounds MCU Flashing Completed, Time: 00:21 IMAGE: rh1050_nai5.71ia Area1: 0x01380000-0x013AFFFF Erased, Time: 00:01 CNT Flashing Completed, Time: 00:01 Extracting Contents Package ... Init Local Mode Failed Contents Package Extracting Failed: Process Failed, Repowering Mobile |
04-27-2009, 07:51 | #7 (permalink) |
Member: 753348 Status: Offline Sonork: no Thanks Meter: 14 | BUT break in flash no full flash here is logs JAF version 1.98.63 Detected PKEY: 90010CB7 Card life counter: 89.43% P-key nokia module version 01.02 Detected UFS_USB V2.8 (c) SarasSoft 2007. version: 01.B1, Driver version: 0, Library version: 0 JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\ USB Cable Driver version: 7.0.2.0 Backup IMEI zone... Setting local mode... Failed! Aborting! Getting MCUID... MCU ID: 0x2292 Reading flash chip detailes... FLASH ID0: 88740089 <=> INTEL -> 28F640W18TE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 MCU ID: 0x2292 Boot is ready... Algo is ready... Loader is ready... Erasing area: 01000000 - 01FFFFFF... Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-105\ Searching for default location of ini... Checking path: \Products\RH-105\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-105\ Scanning ini files... Checking path: \Products\RH-105\ Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-105\ FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.710 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.71ia CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh1050_nai5.71ia ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,Arabic,Farsi,French,Urdu Backing up PM Field 208 as RPL... Setting local mode... Failed! Aborting! Failed to backup imei... MCU: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.710 Booting phone... MCU ID: 0x2292 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 88740089 <=> INTEL -> 28F640W18TE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Flash ID is 0x74888900 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_intel.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x5548; Loader chk: df Loader is ready... P-key nokia module version 01.02 MSID: 842D10F896B466DD171335B045 MSID decoded: 3E4EBAE900C8052AA8000000 FAID: 6433C39D5004F6259A37CFEF Operation took 0 minutes 15 seconds... Erasing... Found 5 interval(s) to erase Erasing area: 01000000 - 0100FFFF... Erasing area: 01010000 - 013AFFFF... Erasing area: 013B0000 - 013EFFFF... Erasing area: 017C0000 - 017EFFFF... Erasing area: 01FC0000 - 01FEFFFF... Operation took 0 minutes 42 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 20 seconds... Restarting MCU... PPM: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.71ia Booting phone... MCU ID: 0x2292 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 88740089 <=> INTEL -> 28F640W18TE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x74888900 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_intel.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x5548; Loader chk: df Loader is ready... P-key nokia module version 01.02 MSID: 84B8F9C3C535DB3CFD1FA627F7 MSID decoded: 3E4EBAE900C8052AAA000000 FAID: 8F68F7DEE9E6824A65AA2FA9 Operation took 0 minutes 14 seconds... Erasing PPM... Found 2 interval(s) to erase Erasing area: 01240000 - 0124FFFF... Erasing area: 01250000 - 0137FFFF... Operation took 0 minutes 13 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 10 seconds... Restarting MCU... CNT: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh1050_nai5.71ia Booting phone... MCU ID: 0x2292 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 88740089 <=> INTEL -> 28F640W18TE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x74888900 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_intel.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x5548; Loader chk: df Loader is ready... P-key nokia module version 01.02 MSID: 842D10F896B466DD171335B045 MSID decoded: 3E4EBAE900C8052AA8000000 FAID: 6433C39D5004F6259A37CFEF Operation took 0 minutes 14 seconds... Erasing Content Pack... Found 1 interval(s) to erase Erasing area: 01380000 - 013AFFFF... Operation took 0 minutes 2 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 1 seconds... Restarting MCU... Operation took 0 minutes 1 seconds... Flashing Done! Operation took 2 minutes 49 seconds... After flash processing... Waiting for phone to boot... Failed! Aborting! |
04-27-2009, 09:00 | #9 (permalink) |
No Life Poster Join Date: Sep 2006
Member: 343326 Status: Offline Thanks Meter: 1,463 | @ ADNAN440-BANNU No one is blind here. You don't need post here all these thing's in Big Red font's Also if u have a problem then ask to any member in simply way not this way. For u r problem.... Full earase the flash & full flash the set with 6.XX version. May u r problem solve. |
1208 flashing error is it hardware | dapinderjit | Nokia Hardware & Hardware Repair | 12 | 08-01-2009 18:35 |
1208 flash error need help | /\/\A/\/| | Nokia Digital Core Technology 4 ( DCT-4 ) | 4 | 06-29-2009 19:29 |
1208 Flash Error Help | M Maqsood | Nokia Digital Core Technology 4 ( DCT-4 ) | 3 | 03-31-2009 14:49 |
1208 flashing error need help | ameho0102 | Nokia Hardware & Hardware Repair | 8 | 12-23-2008 09:26 |
