11-14-2006, 18:24 | #1 (permalink) |
No Life Poster Join Date: Oct 2006 Location: Jammu & Kashmir (India)
Member: 367928 Status: Offline Thanks Meter: 178 | 1600 Big Problem |
11-16-2006, 00:57 | #2 (permalink) |
No Life Poster Join Date: Mar 2006 Location: pakistan Age: 71
Member: 241039 Status: Offline Thanks Meter: 4,170 | 1600 dear u should flash the fone , then UI setting and full factory defalt , if ur prob still there , so reheat with good paste , if exist the fault , its fault of UEM , |
11-16-2006, 00:58 | #3 (permalink) |
11-16-2006, 08:40 | #4 (permalink) |
Freak Poster Join Date: Oct 2006 Location: Hyderabad, INDIA Age: 48
Member: 379342 Status: Offline Thanks Meter: 16 | sir the sets which are mishandled should be taken alot care while servicing because the set might go to dead conition.as you set the is fallen down and the problem is with network plz check loose contacts in networkarea .check antenna switch, p/a and R.F processor.finally check imei and repair it with software. |
1600 big problem | manyosa | Nokia Hardware & Hardware Repair | 4 | 09-05-2012 08:24 |
big problem with my mx key | sshreesai | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 03-31-2010 10:07 |
6085 big problem | kami1987 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 03-29-2010 13:42 |
1600 Big Problem | sajithcellular | Nokia Hardware & Hardware Repair | 4 | 05-10-2008 16:42 |
