04-17-2008, 13:18 | #1 (permalink) |
Freak Poster Join Date: Apr 2008 Age: 38
Member: 751223 Status: Offline Sonork: mobilecenter88 Thanks Meter: 538 | 1600 flashing error 2nd Boot: u_2nd.fia, Ver: 4.69.0 Fl0: 0x01000000-0x013FFFFF,00EC2268,Sam K8S3215ETE Algorithm: u_amd.fia, Ver: 4.69.0 Algorithm Ok, MSID: 845B6B42F3B16A6C3E0D04E9C0 Decoded MSID: 3E4EBAE9-00C939AF-A9000000 Encoded FAID: 4FABD340-A1A4FE91-C55A57F9 IMAGE: rh64_07.020 Area1: 0x01000000-0x0100FFFF Erased, Time: 00:00 Area2: 0x01010000-0x013BFFFF Erased, Time: 00:27 Area3: 0x013C0000-0x013EFFFF Erased, Time: 00:08 Area4: 0x017C0000-0x017EFFFF Out of Chip Bounds Area5: 0x01FC0000-0x01FEFFFF Out of Chip Bounds Write Error: hDat 14, at: 0x01000000:08 Process Failed, Repowering Mobile reball cpu but same condition this prob are related by flash help any one |
The Following User Says Thank You to mohammed-anis For This Useful Post: |
04-26-2008, 10:43 | #5 (permalink) |
Freak Poster Join Date: Sep 2007 Location: india Age: 35
Member: 587695 Status: Offline Thanks Meter: 61 | 1600 Flash Error Getting MCU ID MCU ID: 0x2201 FLASH ID0: 2A7E0001 <=> SPANSION -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: 24 32 B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Checking RAM for ALGO... Algo is ready... Checking FAID calculation... P-key nokia module version 01.01 Done! Phone Restarted... Backing up PM Field 208 as RPL... Setting local mode... Failed! Aborting! Failed to backup imei... MCU: C:\Program Files\Nokia\Phoenix\Products\RH-64\rh64_06.900 Booting phone... MCU ID: 0x2201 BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A0 Boot is ready... FLASH ID0: 2A7E0001 <=> SPANSION -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: 24 32 B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x7E2A0100 Flash loader is C:\Program Files\ODEON\JAF\Flash\u_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7518; Loader chk: c6 Loader is ready... P-key nokia module version 01.01 MSID: 842206D45B57D9C86FA28ACB3E MSID decoded: 3E4EBAE900C7CD3DAA000000 FAID: AB25D72308AF91F0F135FEDE Operation took 0 minutes 13 seconds... Erasing... Found 5 interval(s) to erase Erasing area: 01000000 - 0100FFFF... Erasing area: 01010000 - 013BFFFF... Erasing area: 013C0000 - 013EFFFF... Erasing area: 017C0000 - 017EFFFF... Erasing area: 01FC0000 - 01FEFFFF... Operation took 0 minutes 27 seconds... Writing... Error cmd: 14! Addr: 01080000 |
04-26-2008, 17:26 | #6 (permalink) |
No Life Poster Join Date: Nov 2005 Location: UNLOCKING IN GENERAL:) Age: 51
Member: 196126 Status: Offline Thanks Meter: 80 | 6310 flashing problem Hi all similar problem here 6310 i can easily erase flash but cannot program it again it stops at the very beginning same error in jaf as above i did change flash ic still same any advices? BR |
04-26-2008, 20:39 | #7 (permalink) |
Insane Poster Join Date: May 2007
Member: 508595 Status: Offline Thanks Meter: 14 | HI buddies, 1st of ALL try to full erase , then Write UEM, and then flash, Most of the time it is happend due to loose contact of cable from UFS to PHONE cable connector, hold during process, no need to change anything It will be ok. Just clean the board. and flash with MCU rh64_06.010, ppm rh64_06.010, cnt rh64_06.01ud and 1600_digi_01.pp, after flashing with this phone display only lights (blank) and again flash with other language version It will be ok. tested by me. after that post result |
04-29-2008, 01:08 | #8 (permalink) |
Major Poster Join Date: Mar 2001 Location: The Netherlands
Member: 3821 Status: Offline Thanks Meter: 1 | Yes, it's defenitly cable problem from box to phone. Make sure all the pins make good contact with phone. I had the same problem: flash erased till 16%, then error, backup PM Field 208 faild, etc.. |
05-20-2008, 07:21 | #9 (permalink) |
Junior Member Join Date: Mar 2008
Member: 729498 Status: Offline Thanks Meter: 0 | contect service 1600 1st Boot Ok, DCT4, UPP: 2201 Fl0: 0x01000000-0x01FFFFFF,00EC2268,Sam No Name Algorithm: u_amd.fia Algorithm Ok, MSID: 84F2BC4C82A43E6515798D80EADecoded MSID: 3E4EBAE9-00053429-AA000000 Encoded FAID: 16E5204D-2C71DFE1-F421C860 Erasing: 0x01000000-0x0100FFFF ... Erasing Error: 10, at: 0x01000000-0x0100FFFF, 940207, Time: 00:00Process Failed, Repowering Mobile |
05-20-2008, 07:25 | #10 (permalink) | |
No Life Poster Join Date: Sep 2006
Member: 343326 Status: Offline Thanks Meter: 1,463 | Quote:
First just reball flash IC then try & post rsult. | |
05-20-2008, 07:26 | #11 (permalink) | |
Post result. | |
1600 flashing error | amol_sm | Nokia Digital Core Technology 4 ( DCT-4 ) | 8 | 07-25-2007 09:32 |
1600 flashing error | jmustufa | Nokia Hardware & Hardware Repair | 4 | 07-11-2007 20:25 |
1600 flash error | jothi737 | Nokia Digital Core Technology 4 ( DCT-4 ) | 2 | 05-27-2007 18:04 |
1600 flashing error | amol_sm | Nokia Digital Core Technology 4 ( DCT-4 ) | 3 | 05-03-2007 17:23 |
