07-31-2009, 12:00 | #1 (permalink) |
Freak Poster Join Date: May 2008
Member: 772242 Status: Offline Sonork: 100.1640371 Thanks Meter: 45 | 1650 problem Getting MCU ID MCU ID: 0x2292 FLASH ID0: 88280020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Checking RAM for ALGO... Algo is ready... Checking FAID calculation... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Switching to serial... Powering the phone... Failed! Aborting! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\phoenis\products\rh-99\rh99_05.800 PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\phoenis\products\rh-99\rh99_05.800 PPM Flash file: C:\Program Files\Nokia\phoenis\products\rh-99\rh99_05.80ej CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,Russian,Ukrainian Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\phoenis\products\rh-99\rh99_05.800 PPM Flash file: C:\Program Files\Nokia\phoenis\products\rh-99\rh99_05.80ej CNT Flash file: C:\Program Files\Nokia\phoenis\products\rh-99\rh990_nai5.80ej ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,Russian,Ukrainian Backing up PM Field 208 as RPL... Setting local mode... Failed! Aborting! Failed to backup imei... MCU: C:\Program Files\Nokia\phoenis\products\rh-99\rh99_05.800 Booting phone... MCU ID: 0x2292 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 88280020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x28882000 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_st_i.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x4B38; Loader chk: df Loader is ready... P-key nokia module version 01.02 MSID: 84BEA55304F40EE0302A50AA30 MSID decoded: 3E4EBAE900D928AAA9000000 FAID: 71677ECB5258619202920FDA Operation took 0 minutes 14 seconds... Erasing... Found 5 interval(s) to erase Erasing area: 01000000 - 0100FFFF... Erasing area: 01010000 - 013AFFFF... Erasing area: 013B0000 - 013EFFFF... Erasing area: 017C0000 - 017EFFFF... Erasing area: 01FC0000 - 01FEFFFF... Operation took 1 minutes 8 seconds... Writing... Error cmd: 14! Addr: 01000064 All of them stops at this particular point.Friends pls what could be the cause of this. |
08-03-2009, 08:48 | #4 (permalink) | |
No Life Poster Join Date: Sep 2007
Member: 594753 Status: Offline Sonork: 100.1605626 Thanks Meter: 822 | Quote:
power ic problam...................... | |
08-03-2009, 08:51 | #5 (permalink) | |
08-03-2009, 08:52 | #6 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Inside of GsmhostinG
Member: 707582 Status: Offline Sonork: 100.1620432 Thanks Meter: 334 | bro, try this metherd step by step 1. check your cable 2. errase full flash and flash again 3. remove charging connector and flash again 4.reflow flash ic/ reball flash ic post result best regards |
The Following User Says Thank You to VIBINDAS_INDIA For This Useful Post: |
08-03-2009, 08:55 | #7 (permalink) |
Insane Poster Join Date: Jun 2008 Location: Benguet, Philippines
Member: 795033 Status: Offline Thanks Meter: 9 | may be there's a problem with the instullation of your gadget, or try other flash file may be the flash file you are using is corrupted or try to flash it with other gadget. thanks! |
08-03-2009, 10:19 | #8 (permalink) |
Crazy Poster Join Date: Mar 2009
Member: 984054 Status: Offline Sonork: 12345 Thanks Meter: 9 | flash ic problem check ur log "Getting MCU ID MCU ID: 0x2292 FLASH ID0: 88280020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Checking RAM for ALGO... 100% flash ic problem Algo is ready... |
The Following User Says Thank You to p.rahulganesh For This Useful Post: |
1650 problem | gilani4_all | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 07-22-2008 07:47 |
1650 problem | Ghazi4_all | Nokia Base Band 5 ( BB-5 ) | 0 | 05-30-2008 06:55 |
again 1650 problem | alimuamin | Nokia Hardware & Hardware Repair | 2 | 05-28-2008 05:51 |
1650 problem | f164 | HWK | 8 | 05-17-2008 19:18 |
