01-08-2010, 10:47 | #1 (permalink) |
Registered User Join Date: Dec 2007 Location: krishnagiri
Member: 645764 Status: Offline Thanks Meter: 208 | 1661 hanging problem MCU SW version: V 03.70 14-04-09 RH-122 (c) Nokia HW version: 1501 PCI version: UEM version: 1328 UPP version: 8851 RFIC version: 0700 DSP version: ICPR81_09w10_UPP LCD version: UNKWN: IDs: fe:80:00 PPM version: V 03.70 14-04-09 RH-122 (c) Nokia MI ADSP SW version: V 03.70\n14-04-09\nRH-122\n(c) NMP\nmi Production serial number: IIQ347749 Product code: 0576996 Module code: 0204078 Basic production code: 0575464 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 356921******** IMEI spare to net: 3A 65 29 01 43 97 26 03 IMEI SV to net: 33 65 29 01 43 97 26 23 F5 Master Code: 7204304354 Phone type: RH-122, Software version: 03.70, Language Pack: MI User code: ÿ# Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RH-122.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0576996 Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-122\ any other solution .......................... |
The Following User Says Thank You to ka jagan For This Useful Post: |
01-08-2010, 10:58 | #2 (permalink) |
Freak Poster Join Date: Aug 2009 Location: Bangladesh/UAE
Member: 1108551 Status: Offline Sonork: Jerry Thanks Meter: 153 | your phones.. User code: ÿ# try with rh-122_dp_v_03_51_mcusw03_75 file |
The Following User Says Thank You to jerrymamun2009 For This Useful Post: |
01-08-2010, 16:04 | #4 (permalink) | |
No Life Poster Join Date: May 2008 Location: P@Ki$t@n
Member: 777415 Status: Offline Sonork: 1589702 Thanks Meter: 1,420 | Quote:
01-08-2010, 17:15 | #5 (permalink) | |
Freak Poster Join Date: Mar 2009
Member: 994980 Status: Offline Thanks Meter: 69 | Quote:
01-08-2010, 22:35 | #6 (permalink) | |
Registered User Join Date: Aug 2009
Member: 1087294 Status: Offline Thanks Meter: 252 | Quote:
1661 keypad problem | fonejack | Nokia Hardware & Hardware Repair | 32 | 03-02-2013 11:01 |
1661 light problem | neeraj1st | Nokia Hardware & Hardware Repair | 14 | 10-21-2011 16:08 |
need 1661 hang white display soln | rajendrakumar | Nokia Hardware & Hardware Repair | 28 | 04-20-2011 06:56 |
1661 light problem | nadeem126 | Nokia Hardware & Hardware Repair | 0 | 07-21-2009 09:00 |
kg195 hanging problem logo hang | rameez_gsm | Infinity-Box | 7 | 01-22-2009 14:41 |
