Old 03-23-2008, 09:12   #1 (permalink)
soy
soy's Avatar
Member: 220932
Sonork: 100.1592154
Thanks Meter: 110
2100
hi to all 2100 which is showing chargein but not saveing chargeing what can i do ....................?
Old 03-23-2008, 14:17   #2 (permalink)
mobilespeed's Avatar
Member: 706300
Thanks Meter: 147
Thumbs up re:
" change charging ic problem solved"
Old 03-23-2008, 15:54   #3 (permalink)
alamgarh's Avatar
Member: 358694
Sonork: 100.1597323
Thanks Meter: 994
dont change charging ic. Just and first change its battery becasue i have tested many times. and post result.
Old 03-23-2008, 16:00   #4 (permalink)
venusmobilecare's Avatar
Member: 572808
Thanks Meter: 607
yes i m agree with alamgarh
1.change tested battey-if not solved
2.changed battery connecter-if not solved
3.change pfo-if not solved
4.change chargng ic
good luck
imran
Old 03-23-2008, 16:38   #5 (permalink)
baywalker's Avatar
Member: 260002
Thanks Meter: 8
yup changing battery will do
Old 03-24-2008, 09:48   #6 (permalink)
Sagitarious's Avatar
Member: 615730
Thanks Meter: 256
I have 2100 but when signal show the set is goes off......
I dont have PA, anybody have jumper of PA..
Old 03-24-2008, 11:40   #7 (permalink)
Cheater -Don't Deal with him-
Member: 622382
Thanks Meter: 201
change pa ur problem solved
Old 03-24-2008, 13:52   #8 (permalink)
Member: 588028
Thanks Meter: 2
thanks all of you................................
Old 03-24-2008, 14:40   #9 (permalink)
jimm07ct's Avatar
Member: 426688
Sonork: 100.1596204
Thanks Meter: 524
bro,
check charging output
if less then 3.5v then change charging ic
if output ok then change pa
best of luck
Old 03-24-2008, 14:42   #10 (permalink)
jimm07ct's Avatar
Member: 426688
Sonork: 100.1596204
Thanks Meter: 524
bro,
jumper is not perfect solution
you need to change pa
Old 03-26-2008, 04:26   #11 (permalink)
soy
soy's Avatar
Member: 220932
Sonork: 100.1592154
Thanks Meter: 110
4.change chargng ic
good luck
imran
i also check your 4 step but problam same
any other slution
Old 03-26-2008, 08:39   #12 (permalink)
Member: 706300
Thanks Meter: 147
re:
any other slution
" there is no other option besides charging ic in urs problem & i mean it"
2100 short circuit need 2100 diagram erkan06us Nokia Hardware & Hardware Repair 8 05-13-2006 09:14
SGH-2100 Contact provider D-Brain Samsung Hardware Repair 2 01-19-2002 14:24
samsung 2100 after 20sec call end tone Samsung Hardware Repair 2 12-16-2001 13:04
unlockclips for panasonic and samsung 2100+2400 aj1rtd Main Sales Section 0 09-06-2001 00:15
Samsung sgh-2100 Pandemonio100 Samsung Hardware Repair 2 09-04-2001 18:59
Page generated in 0.24025 seconds with 9 queries
