12-03-2007, 20:50 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: karachi
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | ..::2100 auto and not charging::.. ..::HUM::.. |
12-03-2007, 21:11 | #2 (permalink) |
Junior Member Join Date: Dec 2006
Member: 416676 Status: Offline Thanks Meter: 5 | connect charger,remove battery,measure charging voltage on battery connector,it must approx the battery voltage about 3,6 dcv,if charging voltage is below 3,6 dcv (eq. 2 dcv)your phone wont charge,check the charging line if there's any small component short with ground,try to reach the charging voltage (3,6 dcv) |
06-16-2008, 08:07 | #6 (permalink) |
No Life Poster Join Date: Feb 2007 Age: 41
Member: 449518 Status: Offline Thanks Meter: 585 | connect charger,remove battery,measure charging voltage on battery connector,it must approx the battery voltage about 3,6 dcv,if charging voltage is below 3,6 dcv (eq. 2 dcv)your phone wont charge,check the charging line if there's any small component short with ground,try to reach the charging voltage (3,6 dcv)......... |
...::hot triks 4 bb5 not charging::.. | snisar | Nokia Hardware & Hardware Repair | 6 | 10-20-2009 12:42 |
N82 sometimes auto and hang!! | watari31 | Nokia Hardware & Hardware Repair | 5 | 07-31-2009 15:17 |
auto pinout not detect not working | janki_amreli | SpiderMan | 0 | 01-19-2009 19:09 |
1110 auto say not charging without charger plz help | amanhalwara | Nokia Hardware & Hardware Repair | 3 | 11-26-2007 09:31 |
3310 When Charged Auto On And Not Charging | remylebeau | Nokia Hardware & Hardware Repair | 6 | 03-27-2007 13:26 |
