08-11-2011, 12:48 | #1 (permalink) |
Moderator Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | 2700c/5130c insert sim : step by step solution here I show u , how to repair insert sim problem of okia 2700c & 5130c ( because both r same type of pcb) there is no sim esd filter in this sets , sim card controlling circuit r in avilma. first we check vsim voltage 2.8v in linefilter L2704 from avilma( in first picture) . vsim 2.8v supply from avilma. if no voltage obtain or less voltage , first remove two filter chipcaps C2700 & C2702 . after remove that two chipcaps we need to check vsim voltage again in L2704 . if still no voltage obtain or less go to second step. in vsim voltage output line there is another twin filter capasitor C2220 , value 1.5mfd/6.5v . if it's damage or shorted then also insert sim problem aeries . (see in picture no three) so remove that twincapasitor then check for vsim voltage . if still same then we need to change avilma. simrst,simclk,simio line goes to avilma directly . so if vsim voltage is normal but can't detect sim by mobile then avilma should be faulty & we need to replace avilma with new one. sometiems it's also due to loose solder joints under avilma . so before replace reball avilma then check. I don't mention to check simcard tray or jacket (X2700) because it's a common issue. please feel free to ask anything if u don't understand . or if u have a better way please share. |
The Following 2 Users Say Thank You to .:SARCAR:. For This Useful Post: |
11-11-2011, 18:24 | #2 (permalink) |
Junior Member Join Date: Nov 2011
Member: 1687535 Status: Offline Thanks Meter: 2 | thank you sir. but I still want to ask. I have a problem insert sim 2700c \. vsim voltage was not there. I do advice you and claim avilma damaged. but after I disassembly avilma it turns out Pin SimDaC2 was broken, but I still do the replacement part. consequently it does not appear vsim. I would ask what the function of these pins and how to resolved this problem. thanks b4 |
The Following User Says Thank You to adrian' For This Useful Post: |
11-11-2011, 20:01 | #3 (permalink) |
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | @adrian' , 'simdac2' not needed but simdac1 needed , so no problem for track damage of simdac2 (avilma C8 pin). & for vsim voltage read my above post . "in vsim voltage output line there is another twin filter capasitor C2220 , value 1.5mfd/6.5v . if it's damage or shorted then also insert sim problem aeries . (see in picture no three) so remove that twincapasitor then check for vsim voltage . if still same then we need to change avilma." |
The Following User Says Thank You to .:SARCAR:. For This Useful Post: |
SIM restriction pending -- what does it mean? | Ryu | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 07-17-2011 10:05 |
