12-02-2009, 16:14 | #1 (permalink) |
Freak Poster Join Date: Jan 2007 Location: mozila firefox/ gsmhosting.com
Member: 426107 Status: Offline Thanks Meter: 64 | 3110c not power on i flashed with hwk with rm237 v7.21 flash file sucessfull . ui setting ok. but no power on. on the power switch voltage shows 0.00 not 3.6 here is the log and self test please give solution. ************************** info MCU SW : V 07.21 05-11-08 RM-237 (c) Nokia. PPM SW : V 07.21 05-11-08 RM-237 (c) Nokia. I Prd.Code: 0549190 Bpr.Code: 0548284 Prod.Sn : 7C5368736 HW Vers : 1001 EM RETU : 32 EM TAHVO: 53 RFIC Ver: 17211721 DSP Vers: ICPR61_08w10 IMEI : 352048-02-162025-0 SL Serv : SIMLOCK SERVER VERSION 63 SL Conf : 244-07-00000000000 SL Prof : 0000000000000000 SL Count: 00 00 BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN Provider: Nokia Test;Finland |
12-02-2009, 18:27 | #5 (permalink) |
Freak Poster Join Date: Oct 2009
Member: 1150643 Status: Offline Thanks Meter: 40 | first check the switch on-off, check VBAT, or try to turn on the power supply and check how the current consumption |
The Following User Says Thank You to mayor_NY For This Useful Post: |
nokia 3110c not power on with Battery | kariakala | Nokia Hardware & Hardware Repair | 5 | 08-01-2011 11:21 |
NOKIA 3110c CHARGING OK but NOT POWER ON | lovist2 | Nokia Hardware & Hardware Repair | 21 | 11-10-2010 13:41 |
3110c not power on help | vaghubha_sodha | Cyclonebox | 12 | 10-28-2009 04:36 |
nokia 3110c not power on | nishatmohd | Nokia Hardware & Hardware Repair | 7 | 05-10-2009 08:45 |
Nokia 3110c ful flash but not power on dead | dey mobiles | Nokia Base Band 5 ( BB-5 ) | 4 | 05-02-2009 14:43 |
