Old 01-20-2008, 11:56   #1 (permalink)
Member: 301177
Thanks Meter: 91
3120 Restart Problem
hello friends i have a nokia 3120 restart problem when i insert the sim and on the phone after few second the phone is restart i also flash the phone with higher virson 6.11 flash file and after a one day the problem is repat please help
thanks
Old 01-20-2008, 17:54   #2 (permalink)
Registered User
Member: 557494
Thanks Meter: 14
reheat flash ic and your phone will get work normal
Old 01-20-2008, 19:06   #3 (permalink)
.:.unlockers's Avatar
Member: 269230
Thanks Meter: 5
Yes reheat flash ic your problem will be solved tested by me 100% working.
.:.unlockers
Old 01-21-2008, 10:19   #4 (permalink)
sopnil's Avatar
Member: 528679
Thanks Meter: 268
hi, if without sim set is ok then problem is uem ic but one thing some couses come restart some time battery fluty and some time flasher and some time pa problem also set take auto restart also if battery losses also take auto restart
now at first u will do rehot uem ic if not done then change uem ic.......
sopnil
Old 01-21-2008, 10:27   #5 (permalink)
Member: 428935
upp fulty reball or replace........
Old 01-24-2008, 18:05   #6 (permalink)
Member: 301177
Thanks Meter: 91
i reflow the flash and uem the phone is ok after 2 days the problem is back on the handset pls help what can i do
Old 01-24-2008, 19:42   #7 (permalink)
Member: 275631
Thanks Meter: 408
just reball upp and flash.....
bro 3100/20 is the easiest phone to repair...
my way of doing it is that i remove all four ics
UEM, UPP, FLASH n MJOLNER
clean the board properly reball all ics and put them back
thats it
and all it take is about 20 mins
Old 01-25-2008, 06:08   #8 (permalink)
Member: 244357
Thanks Meter: 70
dear reball or heat the mcu and flash. your problem will be solved.
Old 03-18-2008, 17:26   #9 (permalink)
Member: 307420
Thanks Meter: 17
hello sir i cand understand which ic problem now plse help me
Old 03-18-2008, 17:29   #10 (permalink)
Member: 307420
Thanks Meter: 17
hello khalifa now i have done thease are all but now still the same problem plse help me
thats it
Old 03-18-2008, 17:46   #11 (permalink)
mobilespeed's Avatar
Member: 706300
Thanks Meter: 147
Thumbs up re:
" nothing is left bro what r u waiting for but i do say very good work, keep it up, now do one thing change rtc"
Old 03-18-2008, 17:52   #12 (permalink)
baywalker's Avatar
Member: 260002
Thanks Meter: 8
try to use the erase flash first and then flash using the latest version. If the same problem try to reheat or reballs the flash IC
Old 03-18-2008, 17:57   #13 (permalink)
humayun's Avatar
Member: 173592
Thanks Meter: 30
rehot flash ic bro n full flash with letest version
Old 03-18-2008, 17:58   #14 (permalink)
Member: 706300
Thanks Meter: 147
re:
" havnt u read the post , it is assumed from that he have erased flash"
Old 03-20-2008, 17:47   #15 (permalink)
Registered User
Member: 437195
Thanks Meter: 1,734
bro its hardware problem
rehot flash,cpu
Nokia 3120 Network Problem ramdev_mobbile Nokia Hardware & Hardware Repair 3 07-13-2010 08:46
3120 restarts jbbasha Nokia Hardware & Hardware Repair 3 06-28-2006 19:36
3120 restart problem mohamedsafi123 Nokia Hardware & Hardware Repair 2 06-12-2006 18:19
3120 restarts at writing sms ren77 Nokia Hardware & Hardware Repair 6 04-05-2006 15:40
Page generated in 0.18227 seconds with 10 queries
