.::3250 camera 2 types pcb problems solved::. I had problem with 3250 camera "general: feature not supported". My version of pcb was different from one shown in service schematic. In my case the smallest fuse on the right was broken, so I've replaced it with good one (you can short it with wire of course). Here's how I solved the problem: See Attachment 1 Try this solution! Its 100% working.... I tried it! But of course try to check first these two fuse with tester.... in Attchment picture if theres no continuity then change it if not make a jumper.... basically the smaller fuse often ****n.... But some 3250 board, the smaller fuse was not been used and the capacitor (C1110) is present align with connector... http://img393.imageshack.us/img393/1867/7508ve2.jpg http://img513.imageshack.us/img513/9...camera2ao9.jpg |
:( change fuse butt problem still there what can i do? |
Yes. Have wire with F1110 but can not. Have use Ohm electric then have Vbat 37v Ok. What problem with me ? |
on the strip two transistors are faulty |
