07-09-2007, 06:26 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: I N D I A
Member: 336212 Status: Offline Sonork: 100.1585000 Thanks Meter: 4,912 | .::3250 camera 2 types pcb problems solved::. I had problem with 3250 camera "general: feature not supported". My version of pcb was different from one shown in service schematic. In my case the smallest fuse on the right was broken, so I've replaced it with good one (you can short it with wire of course). Here's how I solved the problem: See Attachment 1 Try this solution! Its 100% working.... I tried it! But of course try to check first these two fuse with tester.... in Attchment picture if theres no continuity then change it if not make a jumper.... basically the smaller fuse often ****n.... But some 3250 board, the smaller fuse was not been used and the capacitor (C1110) is present align with connector... |
The Following User Says Thank You to .::AZEEM::. For This Useful Post: |
07-09-2007, 07:40 | #2 (permalink) | |
No Life Poster Join Date: Jul 2005 Location: ludhiana~india Age: 38
Member: 163833 Status: Offline Sonork: 100.1579554 Thanks Meter: 5,700 | Quote:
3250 camera 2 types pcb problems solved | sidcho | Nokia Hardware & Hardware Repair | 36 | 07-05-2011 11:54 |
..::All Gsm Warker:S60v3..n73,3250etc softwares problem solved::.. | mehedi.h.j | Nokia Multimedia | 3 | 10-30-2007 10:18 |
