3310 5 second good after it no network 3310 when i turn on for 5 second is OK but after it no network and in speaker i have strange noise. How to repair it. I rehot cobba hagar. and nothing. PLEASE HELP ME. |
Try to update FAID,if that dont work then you must replace your P.A. If you need more help just ask. |
whats look like p.a ? what is the number of P.a |
If you have network 5 sec -> try rehot CCONT(power control ic) If you have bad noice in head phone when phone search network(Bad Power Amplifier PF08109BN,and you need change it ,or hagar short to GND) I you have bad noice when you call (Try reball cobba or change it) Good Luck! Write result;) |
signal and audio prob...definitely COBBA....if reflowing doesnt give u joy....replace it ...:D |
Re: 3310 5 second good after it no network Zender, Can you try to check, is phone have TX power ? you can get some light up LED when you have make phone call or some one call you. then you try to run wintesla, and set on turn menu -> TX power -> set level 5 , then see that LED light up or not ? if you do not have wintesla.,,, please try make 112 call.. Willy Quote:
Thanks I try it. AND write to you results |
hi zender, 1. write full flash(nokanew) and use nk_calc for calculate flash data and SP data 2. change pf...09 3. change duplexor filter(antenna swich) 4. resoldering hagar, ccont and cobba. if don't work change these. geo |
HI George, What is No: 2 PF...09 ? B.R. Willy Quote:
It's a PA code on top of your phone there |
change PA!!!! i think it will work bcus I had several cases and solved the problem good luck light |
If PA not solved the problem and software FAID is OK Then Change COBBA |
Hi all, i have one problem with 6210 ! Under coba ic is from botom 5 line and from left 3 pin without metal | -coba -| ******** ******** ******** ******** **B***** ******** ******** ******** B= none metal pin (damaged contact) Can any tell me if is needly this pin on pcb? Thanx ! |
