07-31-2002, 05:14 | #1 (permalink) |
Insane Poster Join Date: Nov 2001 Location: poland
Member: 7268 Status: Offline Thanks Meter: 0 | 3310 5 second good after it no network |
07-31-2002, 17:55 | #4 (permalink) |
No Life Poster Join Date: Sep 1999 Location: Europe Age: 43
Member: 461 Status: Offline Thanks Meter: 2 | If you have network 5 sec -> try rehot CCONT(power control ic) If you have bad noice in head phone when phone search network(Bad Power Amplifier PF08109BN,and you need change it ,or hagar short to GND) I you have bad noice when you call (Try reball cobba or change it) Good Luck! Write result |
07-31-2002, 21:39 | #6 (permalink) | |
No Life Poster Join Date: Mar 2000 Location: inside NOKIA phone Age: 58
Member: 1060 Status: Offline Thanks Meter: 10 | Re: 3310 5 second good after it no network Zender, Can you try to check, is phone have TX power ? you can get some light up LED when you have make phone call or some one call you. then you try to run wintesla, and set on turn menu -> TX power -> set level 5 , then see that LED light up or not ? if you do not have wintesla.,,, please try make 112 call.. Willy Quote:
08-02-2002, 04:00 | #8 (permalink) |
No Life Poster Join Date: Jul 2002 Location: Bucharest-Romania Age: 51
Member: 14200 Status: Offline Sonork: Sonork id Thanks Meter: 117 | hi zender, 1. write full flash(nokanew) and use nk_calc for calculate flash data and SP data 2. change pf...09 3. change duplexor filter(antenna swich) 4. resoldering hagar, ccont and cobba. if don't work change these. geo |
08-03-2002, 00:12 | #9 (permalink) | |
Member: 1060 Status: Offline Thanks Meter: 10 | HI George, What is No: 2 PF...09 ? B.R. Willy Quote:
08-03-2002, 21:03 | #11 (permalink) |
No Life Poster Join Date: Jun 2002 Location: Iran Age: 48
Member: 12724 Status: Offline Thanks Meter: 30 | change PA!!!! i think it will work bcus I had several cases and solved the problem good luck light |
The Following User Says Thank You to .::AkhavanGSM::. For This Useful Post: |
10-21-2002, 15:53 | #13 (permalink) |
No Life Poster Join Date: Jan 2001 Location: CZ Age: 44
Member: 3041 Status: Offline Thanks Meter: 0 | Hi all, i have one problem with 6210 ! Under coba ic is from botom 5 line and from left 3 pin without metal | -coba -| ******** ******** ******** ******** **B***** ******** ******** ******** B= none metal pin (damaged contact) Can any tell me if is needly this pin on pcb? Thanx ! |
After write good PM 1208 No network Access . . . ? | amol_sm | Universalbox | 5 | 09-08-2009 15:21 |
Need good NV for KU250 after flash no network | s1emens | FuriousGold | 4 | 05-14-2008 10:27 |
Ust pro 2, E250 after unlock No network & after eeprom No Speaker! | Wais777 | UST Pro II | 7 | 04-09-2008 23:55 |
3310 after flash no network | houdanii | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 9 | 03-18-2006 15:39 |
tornado-3310 after flash no network | gsm_raz | UFS2 + UFS3-Tornadoflasher | 9 | 06-27-2004 09:02 |
