12-01-2002, 12:31 | #1 (permalink) |
Junior Member Join Date: Jan 2001 Location: South Africa
Member: 3167 Status: Offline Thanks Meter: 0 | 3310 Antenna Switch Solution Can someone please send me the diagram for antenna switch solution. Despite having searched for hours, cannot find download anywhere. PLEASE Thnx in advance [email protected] |
12-01-2002, 17:45 | #3 (permalink) |
Crazy Poster Join Date: May 2002 Location: Spain
Member: 11983 Status: Offline Thanks Meter: 0 | Willy, could you explain here what repair this solution? Displexor fails or PA fails? 900 mhz fails or 1800 mhz fails?? And... the jpg means to remove antenna switch and make jumper. Jumper is made, and now? Put antenna switch again or not?? Thanks in advance. Regards. |
12-01-2002, 18:28 | #4 (permalink) |
No Life Poster Join Date: Mar 2000 Location: inside NOKIA phone Age: 58
Member: 1060 Status: Offline Thanks Meter: 10 | Pk2GSM it only for you to test ONLY ! incase you do not have antenna switch on stock, and you need to measure that "is it antenna switch" blocken or not, then you can just "TRY ONLY" ! ( GSM 900) not recommand this ! some report already, after few day, that PA got dead! Willy |
12-01-2002, 19:12 | #5 (permalink) |
Member: 3167 Status: Offline Thanks Meter: 0 | willy, cant log onto http://www.gsmschwantz.com , only to gsmschwantz**** . No section called "zip". Can please send to me. [email protected] Many tnx |
12-02-2002, 05:37 | #7 (permalink) |
Member: 3167 Status: Offline Thanks Meter: 0 | Cant download from there either. Says auth-?? . What is this.. All other files from here download fine. Why only problem with antenna switch solution. Any other alternative downloads? Thanx in advance |
3310 antenna switch question | Destructor | Nokia Hardware & Hardware Repair | 18 | 12-16-2003 14:01 |
6210 antenna switch solution | osmanabu | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 12-12-2003 22:38 |
3310 antenna switch solution | osmanabu | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-21-2003 19:54 |
3310 antenna switch problem | digipulse | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 123 | 11-18-2003 05:06 |
3310 Antenna switch compatibility | DRX | Nokia Hardware & Hardware Repair | 4 | 08-07-2003 17:09 |
