11-19-2001, 20:35 | #1 (permalink) |
Crazy Poster Join Date: Nov 2001 Location: North Sweden, Lappland
Member: 7242 Status: Offline Thanks Meter: 0 | Over drove nokia - "no signal" |
11-20-2001, 22:11 | #4 (permalink) |
No Life Poster Join Date: Oct 2001 Location: -------- Age: 55
Member: 7062 Status: Offline Thanks Meter: 126 | hi., <br />chek the antenna part may b broke then clean the pcb well specially the rf module section o.k heat and reflow the haggar... fdk .. vco..and the pf and chek with a microscoap the antenna switch ... may b it works <img src="biggrin.gif" border="0"> <img src="biggrin.gif" border="0"> <img src="biggrin.gif" border="0"> |
11-21-2001, 16:12 | #6 (permalink) |
Member: 7242 Status: Offline Thanks Meter: 0 | I tryed to reflow cobba and the other components and i get a signal for about 5 sec and after that i disapere completly and i have tryed to reflow it about 6times and 3times i got an signal but it disapere. |
11-21-2001, 17:55 | #7 (permalink) |
Freak Poster Join Date: Nov 2001 Age: 45
Member: 7327 Status: Offline Thanks Meter: 12 | hello m8 change the rx filters & ull get signal 10000% it happend to me with a 8210 , & now working ok . & if the signal comes on & then go , change the<br />P.A. & all will be ok . kind regards . <FONT COLOR="#ffff00" SIZE="1">[ 21 November 2001 18:02: Message edited by: digi_com ]</font> |
11-21-2001, 20:45 | #8 (permalink) |
Freak Poster Join Date: Aug 2001 Location: GSMLAND
Member: 5764 Status: Offline Thanks Meter: 2 | I got problem on 3210, that has signal coming and going out continiously. I reflowed COBBA, changed VCO's, PA's, 13 mHz, 71 mHz, other little filters, still no joy. What else can be done? |
11-21-2001, 22:00 | #10 (permalink) |
Member: 7242 Status: Offline Thanks Meter: 0 | Damit. Not sure if this is the components i shall change: <a href="http://www.inside-gsm.com/Nokia/Nokia_3310/Inside_Nokia_3310/Component_side_description_Nok/component_side_description_nok.html" target="_blank">http://www.inside-gsm.com/Nokia/Nokia_3310/Inside_Nokia_3310/Component_side_description_Nok/component_side_description_nok.html</a> 3 and 5 on this picture? It is the "5. Hitachi PF08109BN dual frequency PA" and "3. Diplexer (RXTX switch)" |
11-21-2001, 22:31 | #11 (permalink) |
Member: 7327 Status: Offline Thanks Meter: 12 | hello m8 look try to measure the voltages found in the service manual first to know if the hager bga is ok, if the voltages r ok , then start by changing the component no 2 i think it will work for u , if u got no signal , then change the pa no 5 ,<br />if it didnt work , then try to make manual search<br />if u got a signal & then gone , then change the <br />Diplexer (RXTX switch) . i think this is a brief description . hope this can help . kind regards . |
6300 nokia "no acess" | msantar | Nokia Hardware & Hardware Repair | 2 | 07-14-2008 14:43 |
help me Nokia 6300 "no signal" | anstar | Nokia Base Band 5 ( BB-5 ) | 1 | 05-25-2008 09:27 |
need help for 6800a "no signal" | jaycoy | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 08-09-2006 14:32 |
9300 "No signal" After DCT4Direct | likwidsky | Dct4Direct | 4 | 08-29-2005 12:18 |
help me t191 "no signal" | ali25 | Motorola Hardware Repair | 0 | 10-05-2004 22:02 |
