03-23-2002, 04:01 | #1 (permalink) |
Insane Poster Join Date: Oct 2001 Location: the netherlands
Member: 6950 Status: Offline Thanks Meter: 4 | 3310 charging problem |
03-23-2002, 06:51 | #2 (permalink) |
Insane Poster Join Date: Feb 2001
Member: 3358 Status: Offline Thanks Meter: 1 | Hi, all. About the same problem for me on 3310. When connect charger, it says ''CHARGING''. When remove charger it also says "CHARGING" When i try to reconnect charger it doesnt respond. When power off and on it says ''CARHGING" without charger ? And after 10seconds phone says" NOT CARGING" or "reconnect charger" I replaced power IC and Ccont, but no succes Dont think its software(calibration), because put different full flashes in phone. Are there more options ? Thanks Mod. |
03-23-2002, 12:12 | #3 (permalink) |
Freak Poster Join Date: Apr 2001 Location: INDIA
Member: 4223 Status: Offline Thanks Meter: 4 | Hello... This fault is not always bcos of Charging IC and CCONT... there r lots of parts who r responsible for Charging... This fault is only bcos of Some Kind a shorting... Most probably bcos of water Fallen to that AREA... To solve this problem u guys must have to clean the board properly... and then rehot all area near the Charging IC and CCONT... But b carefull there is CPU also near the Charging IC... This fault is not so big u can solve it.. just u have to try it Good Luck |
03-25-2002, 06:18 | #4 (permalink) |
Member: 3358 Status: Offline Thanks Meter: 1 | Thanks for reply. A qeuston about cleaning. Im searching good way off cleaning, and your right waterdamage caused this problem. What is the best way off cleaning thes damaged phone. Some tell Ultrasonic some say dont use that !! What liquid will do best for cleaning and will not damage board by desolving something else ? Thanks Mod |
3310 charging problems | Hanukkah | Nokia Hardware & Hardware Repair | 3 | 05-18-2005 15:06 |
3310 Charging problem | Vicky | Nokia Hardware & Hardware Repair | 5 | 10-14-2004 18:59 |
3310 charging problem | SubTen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-18-2001 09:37 |
3310 charging problem | garcea10ro | Nokia Hardware & Hardware Repair | 2 | 10-24-2001 16:07 |
3310 charging problem | pornopig | Nokia Hardware & Hardware Repair | 5 | 10-08-2001 20:37 |
