06-17-2008, 16:13 | #2 (permalink) |
No Life Poster Join Date: May 2006 Location: in the corner Age: 35
Member: 285779 Status: Offline Thanks Meter: 49 | hi . you can try strat it by clean the board if dirty . * replace battery connector if bad . * or replace charging ic . |
The Following User Says Thank You to amei8141 For This Useful Post: |
01-19-2009, 05:20 | #5 (permalink) |
Insane Poster Join Date: Mar 2007 Location: rosario pasig
Member: 476626 Status: Offline Thanks Meter: 6 | i agree i agree it is cuased by shorted or bad PA IC mate... try to change PA |
The Following User Says Thank You to peterjay_barcel For This Useful Post: |
01-19-2009, 05:55 | #7 (permalink) |
Insane Poster Join Date: Oct 2007 Location: india -west bengal-kharagpur
Member: 612829 Status: Offline Thanks Meter: 15 | bro you first chek for pcb shorting fi show short you first change pa ic if not solve the problem then check charger volt in bat connector showing 4volt if not show 4 volt its a charging ic problem if not solve your problem then check power ic &nearest component try this before this process first you change good battery |
3310 charging problems | Hanukkah | Nokia Hardware & Hardware Repair | 3 | 05-18-2005 15:06 |
3310 Charging problem | Vicky | Nokia Hardware & Hardware Repair | 5 | 10-14-2004 18:59 |
3310 charging problem | SubTen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-18-2001 09:37 |
3310 charging problem | garcea10ro | Nokia Hardware & Hardware Repair | 2 | 10-24-2001 16:07 |
3310 charging problem | pornopig | Nokia Hardware & Hardware Repair | 5 | 10-08-2001 20:37 |
