11-02-2002, 22:02 | #1 (permalink) |
Insane Poster Join Date: Oct 2002
Member: 16859 Status: Offline Thanks Meter: 0 | 3310 interesting network problem But it has interesting network problem... Phone founds networks I can make calls works But always after a few second network indicator bar folse down, lost network and then again found automaticaly... I have flashed phone with latest 3 diffrent firmware and calc. FAID But same problem... any idea???????????????? |
11-03-2002, 10:00 | #5 (permalink) |
Freak Poster Join Date: Jan 2001 Location: I.C., R.P.
Member: 3165 Status: Offline Thanks Meter: 0 | is your provider dual band? if yes, chances are your phone is switching from one band to the next due to faulty PA. hence try replacing PA. in my place, there are two rival service providers of which one has dual band capabilities and one is fixed to 900mhz. using the single band provider, i get signal for approximately 8 seconds or about the time the lights went off, signal drops too. on the dual band provider, i loose signal on the same interval but regains automatically (1800mhz). my usual solution is to change PA . |
11-03-2002, 11:04 | #6 (permalink) |
Banned Join Date: Oct 2001 Location: JMB Age: 49
Member: 6919 Status: Offline Thanks Meter: 12 | i have the phone with similar prb.... but my phone signals come and go regularly.....i have change... cobba... connt ... hager...pa.. antena switch...... no result.... still have same prob... br.. |
11-03-2002, 17:17 | #7 (permalink) | |
No Life Poster Join Date: Mar 2000 Location: inside NOKIA phone Age: 58
Member: 1060 Status: Offline Thanks Meter: 10 | Mobilemafia, i think, you will say change 32.768 Khz ! Willy Quote:
3310 wierd network problem | Xanga | Nokia Hardware & Hardware Repair | 1 | 03-29-2003 08:12 |
3310 interesting problem! | .::AkhavanGSM::. | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 03-03-2003 07:42 |
3310 interesting charging problem | hs_ | Nokia Hardware & Hardware Repair | 1 | 02-10-2003 22:49 |
6210 & 3310 interesting problem | patrynio | Nokia Hardware & Hardware Repair | 2 | 12-06-2002 20:35 |
3310 with network problem | VREDNYJ | Nokia Hardware & Hardware Repair | 3 | 09-14-2002 16:03 |
