01-30-2003, 22:13 | #1 (permalink) |
No Life Poster Join Date: Sep 2002
Member: 15837 Status: Offline Thanks Meter: 2 | 3310 LED Problem which chip needs to be changed to solve this ????? or what is the solution, its already been through the water damage ultrasonic bath and that hasn't solved it |
01-30-2003, 22:43 | #2 (permalink) |
No Life Poster Join Date: Oct 2001 Location: No route to host. Age: 44
Member: 6772 Status: Offline Thanks Meter: 17 | First check pin15 of the N400, should be 0V (if not then CPU or N400 or board is the problem). Second measure the resistance of the R403. Should be 10k. Third desolder pin13 of the N400. If lights still on then probably R407 is faulty. Remove R407. If lights still on (with pin13 desoldered and R407 removed) then board is faulty. If lights went off then N400 or R407 is faulty. Remove R407 and solder back pin13 of the N400. If all ok leave it. If not chnage N400. Regards |
04-09-2004, 12:50 | #3 (permalink) |
Junior Member Join Date: Jan 2004 Location: ITALY Age: 71
Member: 48408 Status: Offline Thanks Meter: 0 | 3510i with LED problem Hi, I have a similar problem with a 3510i coming from a water fall. I cleaned the phoe that works perfectly, only the 4 LEDs does not switch on. I checked them and they are OK. What can you suggest me? Thanks a lot for your answer Gianni |
3310 led problem | Giggles | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 02-06-2006 17:18 |
problem changin my 3310 led | don_carleone | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 02-13-2004 20:05 |
3310 Led Problem | saxoo | Nokia Hardware & Hardware Repair | 1 | 07-25-2003 13:48 |
Nokia 3310 LED problem | thetotoman | Nokia Hardware & Hardware Repair | 2 | 06-10-2003 19:15 |
3310 LED always ON | greenapple | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 09-01-2001 21:25 |
