07-07-2002, 01:40 | #1 (permalink) |
No Life Poster Join Date: Nov 2001 Location: Slovakia
Member: 7586 Status: Offline Thanks Meter: 11 | n3330, don't power on, power switch ok I have 3330, can't power on, when i plug it into charger, starts charging. But i can't power it on. power switch is ok, i change from working phone, but no results. Any idea? b.r. Pali |
07-08-2002, 09:58 | #3 (permalink) |
Freak Poster Join Date: Sep 2001
Member: 6200 Status: Offline Sonork: 100.33330 Thanks Meter: 66 | Hi, I have same problem in 8890. The phone was water damaged, but it was working after cleaning. After few days it started this problem.I replaced CCONT and checked the power connections are ok. Still same problem. wbr bre786 |
07-18-2002, 04:47 | #4 (permalink) |
Freak Poster Join Date: Dec 2001 Location: Earth
Member: 7934 Status: Offline Thanks Meter: 0 | Hi Pali, The problem is that the current can't circulated in all the phone or the program is not workinng correctly. So begin by hotting the phone with hot air to avoid bad contacts and if not ok make a full flash with good one... I am waiting for your response in my mail. Good luck |
07-28-2002, 03:43 | #6 (permalink) |
Member: 7934 Status: Offline Thanks Meter: 0 | hi friends, No problem , to repair this begin by using service manual and follow the power circuit, go step by step to view where the current is missing...But you should work by group to resolve this quickly. Good luck |
07-28-2002, 08:48 | #7 (permalink) | |
No Life Poster Join Date: Mar 2000 Location: inside NOKIA phone Age: 58
Member: 1060 Status: Offline Thanks Meter: 10 | Re: n3330, don't power on, power switch ok Pali try this: put battery , plug your charger, and give 2.8V to battery Btemp this pin, look if phone can power up .. if not, check PWRONX at R224 , look is it 3.7V, if not , change your ccont! Willy Quote:
A800 no power on but charging ok | Cat10 | Samsung Hardware Repair | 13 | 03-06-2005 14:58 |
3310 cant power on after switching off | ViperGSM | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-14-2004 19:34 |
8850 not power on, but flashing OK 100% - please help! | uu1dx | Nokia Hardware & Hardware Repair | 1 | 01-09-2003 19:22 |
3310 powers on without switch | mohammed | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-22-2002 14:52 |
8210 don't power on.....but charge ok | Pandemonio100 | Nokia Hardware & Hardware Repair | 4 | 05-15-2002 04:13 |
