Old 07-23-2002, 21:52   #1 (permalink)
dimka's Avatar
Member: 7337
Angry 8250 can't flash - F-Bus not working...
F-Bus not working but M-Bus working ok.
Can this be fixed or CPU is faulty?
Old 07-25-2002, 08:42   #2 (permalink)
Bert's Avatar
Member: 596
Sonork: 100.33096
Thanks Meter: 514
Hello
Pls explain it more detaily , how can you sure the Fbus is not working ? ( what do you mean for Fbus is it the F-bus cable or phone F-bus interface? )
Old 07-26-2002, 21:57   #3 (permalink)
dimka's Avatar
Member: 7337
Sorry I've meant phone F-bus interface!
Phone itself is working ok.
I've tried to reflash it (need to change PPM), but I can't
When I connect it with LogoManager, PC-Locals or WinTesla with M-Bus cable it's working OK, but with F-Bus does not
So I decided that phone F-Bus i-face is damaged. Or maybe not?
Old 07-27-2002, 04:44   #4 (permalink)
Member: 10692
Before doing anything with your phone. Try testing your FBUS cable with another phone.
Old 07-27-2002, 04:50   #5 (permalink)
Member: 14006
I meet this problem too
The problem is I think in cobba
I ****ed cobba with hot air gun and the fbus is working now,
But be careful with hot air guns, you can kill your phone permanently so I advise you to let your actual ppm.
Best regard
Blueman
Old 07-27-2002, 19:57   #6 (permalink)
dimka's Avatar
Member: 7337
Angry
I've checked my cable first of all, before writing here that F-Bus interface doesn't works.
I'll try to reball COBBA and post results here.
Old 07-27-2002, 22:17   #7 (permalink)
Member: 1060
Thanks Meter: 10
Dimka,
If you think, phone have problem , from NOKIA service menual, Fbus tx/rx, 3 part link. they are MCU, CCONT, IR
if your cable to flash other phone is working, then it must not cable or SW problem, most time, Fbus TX can not set High after Mbus is set low during flash init. , please try clean phone Fbus contact pad first , then to check CCONT ..
B.R.
Willy
Old 07-28-2002, 00:53   #8 (permalink)
dimka's Avatar
Member: 7337
Arrow
Cleaning the board is the first that I've made with this phone to flash it. But no use
So what to check: COBBA or CCONT??? Or both?
Old 07-28-2002, 01:01   #9 (permalink)
Member: 1060
Thanks Meter: 10
Dimka,
like what i said, from HW of phone FBUS ,
it is link between MCU to CCONT to IR !
so try CCONT first, and then MCU.
give me your phone type and your mail, i send you service menual, you might can learn more
B.R.
Willy
Old 07-28-2002, 01:32   #10 (permalink)
dimka's Avatar
Member: 7337
Phone is 8250 NSM-3D
my mail is [email protected]
Old 07-28-2002, 01:38   #11 (permalink)
Member: 1060
Thanks Meter: 10
HI Dimka
Check your mail
B.R.
Willy
Old 07-28-2002, 01:57   #12 (permalink)
Member: 1060
Thanks Meter: 10
Dimka,
mail sent.
then you can check BB band, see how FBUS link !
then go to MCU and CCONT to test it , and there is layout test point.....
good luck
Willy
can't unlock w910i server not work Haouas Cruiser Suite 9 08-18-2008 21:12
3330 after flashing keypad (1) not working any can some one help!!! chinex14 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 04-25-2004 18:12
After flashing Blue-tooth not work on 6310 roniri Nokia Digital Core Technology 4 ( DCT-4 ) 19 02-01-2003 18:48
A1018S 99w48 r2a - after Flashing Display is not working , but Phone is Fully Worked TNT Old Ericsson Phones & Sony Phones 8 10-16-2000 12:27
Page generated in 0.21424 seconds with 9 queries
