08-11-2008, 13:51 | #1 (permalink) |
Banned Join Date: Sep 2004 Location: msaken Age: 43
Member: 82201 Status: Offline Sonork: 1576982 Thanks Meter: 32 | can't unlock w910i server not work Code: 14:44:53 SE Full Unlocker v2.12 by Cruiser Team 14:44:53 Initialisation en cours… ! 14:44:53 1. Please see the documentation first (a PDF installed with the application) ! 14:44:53 2. Make sure the appropriate phone modem drivers are installed ! 14:44:53 3. Fill in the connection settings under settings tab ! 14:44:53 4. Turn the phone ON ! 14:44:53 5. Connect the phone… 14:44:59 Se connecte via SEMC USB Flash Device (USB1)… 14:44:59 Device driver version: 1.1.0.12 14:44:59 Device driver date: 9-25-2006 14:44:59 Debut de communication en cours… 14:44:59 Connexion a la Baseband CPU en cours… 14:44:59 Baseband CPU service mode entrant… 14:45:00 Chipset detecte: DB3150 14:45:00 Boot mode: EROM 14:45:00 Envoi du loader en cours… 14:45:01 OTP CID: 52 14:45:01 Stauts OTP: Verouille 14:45:01 Type de produit: Detail 14:45:01 Couleur Effective: Rouge 14:45:01 Envoi du loader en cours… 14:45:05 Communicating with server… E 14:45:25 Error: 0x456E8C36 E 14:45:25 Cannot connect to the server E 14:45:25 Error: 0x28FF3CA4 E 14:45:25 Echec! ! 14:45:25 Deconnecter la batterie et le cable du telephone! ! 14:45:25 Pour rapporter l'erreur cliquer droit sur cette fenetre Last edited by Mainboard; 08-11-2008 at 21:45. Reason: no imeis |
08-11-2008, 13:57 | #2 (permalink) |
Member: 82201 Status: Offline Sonork: 1576982 Thanks Meter: 32 | Code: 14:55:42 SE Full Unlocker v2.12 by Cruiser Team 14:55:42 Initialisation en cours… ! 14:55:42 1. Please see the documentation first (a PDF installed with the application) ! 14:55:42 2. Make sure the appropriate phone modem drivers are installed ! 14:55:42 3. Fill in the connection settings under settings tab ! 14:55:42 4. Turn the phone ON ! 14:55:42 5. Connect the phone… 14:55:52 Se connecte via SEMC WMC Device (COM347, COM346)… 14:55:52 Debut de communication en cours… 14:55:52 Communicating with server… E 14:56:13 Error: 0x7C0FA935 E 14:56:13 Cannot connect to the server E 14:56:13 Error: 0x56BBB28E E 14:56:13 Echec! ! 14:56:13 Deconnecter la batterie et le cable du telephone! ! 14:56:13 Pour rapporter l'erreur cliquer droit sur cette fenetre |
08-13-2008, 18:03 | #5 (permalink) |
Member: 82201 Status: Offline Sonork: 1576982 Thanks Meter: 32 | @mainboard I've buy other logs one other resellers "server allgsmunlock" but same probleme here logs Code: 18:54:52 SE Full Unlocker v2.12 by Cruiser Team 18:54:52 Initialisation en cours… ! 18:54:52 1. Please see the documentation first (a PDF installed with the application) ! 18:54:52 2. Make sure the appropriate phone modem drivers are installed ! 18:54:52 3. Fill in the connection settings under settings tab ! 18:54:52 4. Turn the phone ON ! 18:54:52 5. Connect the phone… 18:56:06 Se connecte via SEMC WMC Device (COM347, COM346)… 18:56:06 Debut de communication en cours… 18:56:06 Communicating with server… E 18:56:27 Error: 0x7C0FA935 E 18:56:27 Cannot connect to the server E 18:56:27 Error: 0x56BBB28E E 18:56:27 Echec! ! 18:56:27 Deconnecter la batterie et le cable du telephone! ! 18:56:27 Pour rapporter l'erreur cliquer droit sur cette fenetre |
08-18-2008, 13:15 | #8 (permalink) |
Freak Poster Join Date: Jun 2003
Member: 32847 Status: Offline Thanks Meter: 5 | I have the same: Code: 15:12:27 SE Full Unlocker v2.12 by Cruiser Team 15:12:27 Initializing... ! 15:12:27 1. Please see the documentation first (a PDF installed with the application) ! 15:12:27 2. Make sure the appropriate phone modem drivers are installed ! 15:12:27 3. Fill in the connection settings under settings tab ! 15:12:27 4. Turn the phone ON ! 15:12:27 5. Connect the phone… 15:13:46 Connecting via SEMC WMC Device (COM117, COM116)… 15:13:46 Starting communication... 15:13:46 Communicating with server… E 15:13:48 Error: 0xF1B843F3 E 15:13:48 Error: 0x7C0FA935 E 15:13:48 Error: 0x56BBB28E E 15:13:48 Cannot connect to the server E 15:13:48 Failed! ! 15:13:48 Please disconnect battery and cable from the phone! ! 15:13:48 To report errors right-click this window |
08-18-2008, 14:02 | #9 (permalink) |
Freak Poster Join Date: Sep 2003 Location: Paradise Age: 60
Member: 39477 Status: Offline Thanks Meter: 14 | Same me too Code: 19:11:27 SE Full Unlocker v2.12 by Cruiser Team 19:11:27 Initializing... ! 19:11:27 1. Please see the documentation first (a PDF installed with the application) ! 19:11:27 2. Make sure the appropriate phone modem drivers are installed ! 19:11:27 3. Fill in the connection settings under settings tab ! 19:11:27 4. Turn the phone ON ! 19:11:27 5. Connect the phone… 19:11:35 Connecting via SEMC WMC Device (COM214, COM213)… 19:11:35 Starting communication... 19:11:35 Communicating with server… E 19:11:37 Error: 0x4C273EAF E 19:11:37 Error data: 0x4C273EAF - 00000004:8010000B E 19:11:37 Error: 0x08C42858 E 19:11:37 Error: 0x7C0FA935 E 19:11:37 Error: 0x56BBB28E E 19:11:37 Cannot connect to the server E 19:11:37 Failed! ! 19:11:37 Please disconnect battery and cable from the phone! ! 19:11:37 To report errors right-click this window |
08-18-2008, 21:12 | #10 (permalink) | |
Member: 82201 Status: Offline Sonork: 1576982 Thanks Meter: 32 | Quote:
W910i microphone not working | Naz66 | Sony Ericsson Hardware Repair | 2 | 08-21-2009 13:06 |
server not working ...Cant Unlock W910i | koa | Cruiser Suite | 2 | 01-26-2009 17:40 |
I try unlock K660 and server not working when will work ?? | wgmmmx | Seking Server | 1 | 05-30-2008 17:16 |
Furious server not work, can't make update | EMINEMGSM | FuriousGold | 4 | 03-17-2008 18:05 |
Why UMTS server not work I have 2000 credit and can't use | wgmmmx | Universalbox | 6 | 05-15-2007 13:24 |
