02-28-2002, 19:55 | #1 (permalink) |
Freak Poster Join Date: Nov 2001 Location: Italy
Member: 7301 Status: Offline Thanks Meter: 0 | 3310 no RX after flashing I've just repaired a "contact service" 3310 reflashing it to correct the MCU Rom checksum. After that I've tryed the phone, but with one operator it receive only 1/5 segnal then no network. With another operator I have full network but I can't make calls. I've tryed to replace PA , but it doesn't helped Any advice?? |
02-28-2002, 20:03 | #2 (permalink) |
Freak Poster Join Date: Apr 2001 Location: Belgium
Member: 4378 Status: Offline Thanks Meter: 0 | hello hi i have same probleme but now t'is ok you most just use an Hot air used up the net Amlifier after you problmemost by resolved i hope so good luck best regards |
03-04-2002, 14:55 | #5 (permalink) |
Freak Poster Join Date: Jul 2001 Location: Moscow Age: 42
Member: 5568 Status: Offline Thanks Meter: 1 | I have 5 3310 than don't find the network after full flashing, FAID, SP calculation... I tried to put different versions of SW into them - no help. Is it software or hardware problem? |
03-04-2002, 20:36 | #6 (permalink) |
No Life Poster Join Date: Oct 2001 Location: -------- Age: 55
Member: 7062 Status: Offline Thanks Meter: 126 | so u must to change antenna switch baby if not working try to reflow the hagar with high air mid heat ... and below the ccount and concentrate heat at its top mid air mid heat ,,, tell me wht happend please |
Nokia 3310 No Power After Flashing | iykemoses | Nokia Multimedia | 3 | 07-31-2005 14:26 |
3310 no signal after flash | Amir-SkillZ | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 04-18-2005 19:31 |
3310 no power after flash | conac | Nokia Hardware & Hardware Repair | 4 | 03-31-2005 20:44 |
3310 no singal after full flashed 20-40 | DrMobile | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 04-02-2002 08:47 |
3310 v 3.24 no display after flash | Ledos | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 04-04-2001 13:02 |
