01-30-2003, 08:14 | #1 (permalink) |
Junior Member Join Date: Dec 2002 Age: 59
Member: 18340 Status: Offline Thanks Meter: 0 | 3310 No signal. help... Help needed. Lot of thanks to all who wil reply. |
02-03-2003, 22:23 | #9 (permalink) | |
No Life Poster Join Date: Mar 2000 Location: inside NOKIA phone Age: 58
Member: 1060 Status: Offline Thanks Meter: 10 | Re: 3310 No signal. help... jigger1001 if net moniter showing NSPS ( no signal power save) ! then it mean Hager to COBBA then IP/QP signal is not given ! or COBBA can not do good demod that wave ! so first you have to see that IP/QP wave is ok or not ! then if not, go to check VRX from CCONT supply to Hager ! also you can try to measuer that TX power out going level and frq is ok or not ! if TX frq and level is ok, then it mean COBBA is ok, and PLL loop from ahger to VCO is OK! then continue, that you have to check that antenna switch , saw fileter to Hager ! if all is ok, then you go to check MAD to Hager via SDATA, SENA, SCLK ! you might need have oscilliscope to "see" ! lot old post in forum , please review and search it ! ps, if PA is short, then phone will not boot up ( no power) . drop signal , it mean, phone got RX , but TX might has problem , and you can do lot test with wintesla ! ( ofcouse you might need cracked version or use PKD-1 ) Willy Quote:
02-07-2003, 14:13 | #10 (permalink) |
Member: 18340 Status: Offline Thanks Meter: 0 | no signal Mates, Thanks Willy, here is further info on the 3310 unit. Using Wintesla Test reading range -100 to -108 dBm. So what is the probable cause of this no signal. Heavy interference can be noticed on my pc monitor if I do a call test. |
06-24-2003, 09:57 | #12 (permalink) | |
No Life Poster Join Date: Jun 2002 Location: Iran Age: 47
Member: 12724 Status: Offline Thanks Meter: 30 | Quote:
?????? I cant understand relation with find network(rx) and PA (tx) | |
help 3310 no signal??????????? | atul_799 | Nokia Hardware & Hardware Repair | 15 | 06-16-2007 17:57 |
3310 no signal, please help! | [email protected] | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 10 | 06-24-2006 09:36 |
Help 3310 No signal | NuengEve | Nokia Hardware & Hardware Repair | 6 | 07-08-2005 00:12 |
3310 No signal PLEASE Help | druid | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 07-03-2002 23:07 |
3310 No Signal !!!!! Plz Help!!!!!!!! | ThE-LyNX | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 11 | 05-16-2002 18:59 |
