3310 while flashing showing unknown flash id hi 3310 or 3315 problem dead ,contact service while flashing it is showing unknown flash id what is the problem pls reply :confused: |
first which soft u use for flash, conform con... ser... in eeprom or in mcu,ppm if in mcu ,ppm then use griffin 100% accept any one flash id. in rolis or knok u must edit config new id. or all prob.... in new productions . like v .6.33 right ?? if in eeprom so i m sorry cause i also dont have any solution for write eeprom in knok or in rolis. or u want to remove son... ser,... then change your flash ic or unlock it . working good. b.r. akki |
100% flash Ic's damage rehot flash Ic's or change it, use nokia tool if you change the flash ic's. 100% worked BR :) :D :) |
maybe you uses tool old |
when you get this message unknown flash id or flash id = 00000000 you must rehot that ic or its better to change it . you will find that ic above flashrom ic ...... |
Your solution Hi, U r right Nokia has changed the flash I.C of new 3310 stock,fULLflash your mobile with GeoFlash ,u can download Geoflash from my gruop after joining it; http://groups.yahoo.com/group/babaphone/ BR Babaphone-KuWAIT. |
thanx very much for this help. b.r. akki ;) |
how can i replace if the 3310 is shorted? |
how can i replace if the 3310 is shorted? plz reply... |
what?............................................. ................... |
replace at least sureball flash ic!100%working... |
