05-23-2005, 11:40 | #1 (permalink) |
No Life Poster Join Date: Feb 2001 Location: Planet EARTH Age: 50
Member: 3194 Status: Offline Thanks Meter: 41 | 3650 blink for 1 second only ..Help!! But with battery only blink for a second. Batt connector, Zocus, Uem, and UPP has been changed. Need help from you friends ... thx u |
05-23-2005, 14:44 | #2 (permalink) |
Freak Poster Join Date: Dec 2003 Location: Russia, Yaroslavl Age: 43
Member: 46415 Status: Offline Thanks Meter: 16 | hi! Try another battery and check BSI circuits (measure resistance bsi-gnd and compare with another phone). Write latest sw and good pm. Execute selftests using griffin or phoenix. |
05-24-2005, 06:29 | #3 (permalink) | |
Freak Poster Join Date: May 2005 Age: 40
Member: 144350 Status: Offline Thanks Meter: 3 | Quote:
05-24-2005, 16:13 | #4 (permalink) |
Member: 3194 Status: Offline Thanks Meter: 41 | n301 = Zocus; already change it , still remain. I wonder if there any difference voltage between Upp V 2.5 and V 3.2 ?? please help me. .... now i have 2 phones with same fault. thx |
05-29-2005, 16:24 | #6 (permalink) |
Insane Poster Join Date: Jul 2004 Location: LA
Member: 72894 Status: Offline Thanks Meter: 23 | Use Griffin flash MCU only with file CCS Erase.fia or Erase Flash0_flash1_Flash2.fia and then flash mcu,ppm,pm format user area factory setting or use tornado erase flash fl0 : 00000000 - 007FFFFF Fl1 : 02000000 - 027FFFFF Fl1 : 04000000 - 047FFFFF and then flash mcu+ppm+write PM format user area fact setting |
05-29-2005, 16:36 | #7 (permalink) | |
Freak Poster Join Date: Jul 2003
Member: 34310 Status: Offline Thanks Meter: 23 | Quote:
With Tornado can use file "3650_erase_flash0_flash1_flash2.fia" to full erase too. | |
05-30-2005, 04:37 | #9 (permalink) |
No Life Poster Join Date: Aug 2004 Location: dasma cavite Age: 46
Member: 78367 Status: Offline Thanks Meter: 11 | yes me too with my 7650 it only blinks when turn on. charge it blinks. cnt be flashd but it detects on cble on all mode and cn power on manually on cble attachd. |
05-30-2005, 05:41 | #10 (permalink) |
No Life Poster Join Date: Mar 2000 Location: inside NOKIA phone Age: 58
Member: 1060 Status: Offline Thanks Meter: 10 | is it "NOKIA " logo show up ? it look like some thing wrong from flash Rom for save PPM ! of NOKIA logo show up, it mean SW check sum correct ! other way, look at current used ! me, i will use RD "Prommer Tools" to do "verify code" , it help a lot to make sure SW were good ! when you force LOCAL mode for boot up phone, it only load MCU core SW , and it not do some "checksum" test . you can try "self tests" ,, it will show lot info to you Willy |
05-30-2005, 08:23 | #11 (permalink) |
Member: 3194 Status: Offline Thanks Meter: 41 | hi willy, selftest always failed at SRam... it can boot again, changed Ram still remain. using ufs normal mode can be done well. i ll try to replace flash ic first then keep in touch |
05-30-2005, 17:44 | #12 (permalink) |
Member: 1060 Status: Offline Thanks Meter: 10 | if your PCB is "dark green", then try to measure each flash rom pin "C9 to C9" and check all SRAM connect to UPP , with VIO and Vflash1 ! it also happen line cut ! |
05-31-2005, 07:00 | #13 (permalink) |
Member: 3194 Status: Offline Thanks Meter: 41 | VIo and Vflash1 connected well ... some of them dark green, some Not .... with ufs in normal mode , i can even call Emergency Call .... willy ...Help .... now i have 7 of this kind faulty .... |
V3 doesn't power on. Lights for 1 seconds before shutting down. | James_S | Smart-Clip | 5 | 09-18-2006 00:08 |
v525- blinks for a second | TELE-MEDIA | Motorola P2k | 8 | 03-14-2006 23:39 |
6630, let's be serious for 1 second please | desgrassia69 | UFS2 + UFS3-Tornadoflasher | 2 | 10-06-2005 00:03 |
"dead" V300: keypad light for 1 second, "maybe" after bad clip-unlock | mourad_t | Motorola P2k | 15 | 06-21-2005 02:09 |
6100 only blinks for 1 sec and nothing | kovbal | Nokia Hardware & Hardware Repair | 3 | 04-19-2004 23:41 |
