05-06-2001, 01:57 | #1 (permalink) |
Freak Poster Join Date: Apr 2001 Location: Switzerland Age: 46
Member: 4172 Status: Offline Thanks Meter: 0 | 5110 screen problem Is sample and it works on a 5110 you remove xpress cover you put a little bit of paper between screen and the plastic case, you don't need to open the phone |
05-07-2001, 10:50 | #4 (permalink) |
VIP-Member Join Date: May 1999 Location: home
Member: 69 Status: Offline Thanks Meter: 0 | this is one of the old tricks the best is to solder the display on the ui interface with his holding clips thats the way that nokia told the service partners or you use a new elastomer for the display this is also way from nokia |
05-18-2001, 17:18 | #8 (permalink) |
Junior Member Join Date: Apr 2001 Location: Laguna Philippines
Member: 4388 Status: Offline Thanks Meter: 0 | the best solution is to remove the steel frame and check the LCD if ok put it back, while putting it back on the board make sure to clip it tite the steel frame on the board. And if notting happen change the LCD. |
5110 profil problem | GSM Deals | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-15-2003 01:54 |
5110 wierd problem | norton | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 08-18-2002 10:16 |
5110 signal problems | V60 | Nokia Hardware & Hardware Repair | 7 | 08-05-2002 00:07 |
nokia 5110 unlcking problems | alyx | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 08-31-2001 09:55 |
5110 SMS problem... | omelette | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-07-2000 14:50 |
