Old 06-19-2006, 11:37   #1 (permalink)
Member: 33690
Thanks Meter: 3,398
N91 Problem
Hi,
I Have This New Nokia N91 Which Says "hard Drive Not Available". Any Ideas, Thanks.
Old 06-19-2006, 12:01   #2 (permalink)
BLIDA's Avatar
Member: 15439
Sonork: 100.43816
Thanks Meter: 52
common problem on n91 (check back cover contact )
br
Old 06-19-2006, 23:26   #3 (permalink)
moienshah's Avatar
Member: 258749
Thanks Meter: 10
Exclamation n 91
  • Is N=91 a BB5
Old 06-20-2006, 08:40   #4 (permalink)
Member: 33690
Thanks Meter: 3,398
Hello
br
HI,
I DID CHECK. EVEN CHANGED THE HDD FROM A WORKING PHONE, BUT STILL THE SAME. HAVE A NICE DAY.
Old 06-20-2006, 09:05   #5 (permalink)
N.I.T's Avatar
Member: 204243
Thanks Meter: 67
Smile
Originally Posted by ahmedksal
HI,
sir thr is a senser(a switch) in the board did u check it
Old 06-20-2006, 21:19   #6 (permalink)
Member: 33690
Thanks Meter: 3,398
Hello
Hi,
Could You Be More Specific As To Where Is The Sensor. Have A Nice Day
Old 08-12-2006, 11:40   #7 (permalink)
Member: 325999
Thanks Meter: 113
I Have Same Problem After Some Time Handset Gating Hot What Can I Do ?
Old 08-17-2006, 20:34   #8 (permalink)
Member: 24741
Thanks Meter: 7
hi
i had the same problem
try to format your hdd by JAF - format file system , and put on battery cover otherwise phone say that "hard Drive Not Available"
form me works fine
Old 02-09-2008, 11:04   #9 (permalink)
DIGITAL BABU's Avatar
Member: 420857
Sonork: 100.1576793
Thanks Meter: 1,734
here is the solution(we do not have to use any of box or sofeware):
1. normally i will turn on the phone and press *#7370# to restore to factory setting first.
2. TAKE OFF BACK COVER. reboot phone by holding the (pen-key), the phone will boot as safemode. (it looks no different from normal mode)
3. go to setting--> harddisk (now you will still see "harddisk is not available")
4. PUT BACK COVER ON (do this slowly). then the phone will work very slow BUT THE PHONE IS NOT HANG.
5. you have to be patient, and press option key, and wait for phone responds, it normally takes from 2mins to 5 mins (some phones responds fast, some phones responds slower, depands how it reads harddisk)
6. after option menu comes up, choose harddisk to format (formatting takes about 15 mins or more, be patient, wait until it finish, after formatting harddisk, every thing will work ok again)
note: after put your backcover back, each key you press, phone will respond very slow, because it's reading harddisk, but THE PHONE IS NOT HANG
Dear members,
more
Device hangs when booting
Cause:
- Corrupt HDD
- Defective HDD
- Defective device
- HDD sticking
Cannot access the HDD
Cause:
- Battery cover not in place
- Magnet missing from battery cover
- Damaged HDD
- Corrupt data on HDD
- Poor interconnect between HDD and PWB
HDD Corrupt
Cause:
- Data installed from factory, that was corrupted
- Applications installed on the HDD by user, not compatible
S60 applications that are not version 3.0 (previous versions) are not compatible with N91.
- Application install process to the HDD by user, that are not compatible
If an application was copied from another device to a PC and then onto the
HDD via mass storage, this will corrupt the HDD. Applications that worked in
non-S60 3.0 devices will not work in the N91 or other S60 3.0 devices
because of binary incompatability. Example: an application that works in a
N70 or 6630 will not work in the N91 or N71. If an application was
downloaded from the MMC of these devices and transferred (drag and Drop)
into the N91, this would corrupt the HDD and the HDD would have to be
formatted to function again.
The N91, on startup, will see applications that were copied from the PC to
the HDD. It will try to install these applications; this will lock the HDD and
not allow access. This problem, with early sw (version 1.0), was only able to be repaired by formatting the HDD with Phoenix, because the USB connection could not access the HDD.
Also, if the customer took a backup of a corrupted HDD image, when they
restore this image to the device it will have the same fault.
If an application was interrupted when it was being installed on the HDD by
a power cycle.
Applications have to be allowed to install uninterrupted
Slow Accessing Applications
Causes:
SMS, MMS, Themes, and some applications if they are loaded onto the HDD, will cause slow access times. All these items should be loaded onto the devices internal memory and not the HDD.
Quick Test tips
If the device will not boot:
- Restart the device with the battery cover removed
If the device boots then there is a HDD issue.
If the device boots but can not see the HDD
- Make sure the battery cover is in place.
- Check that there is a magnet in the B-Cover
Use a metal object (a paper clip works) and see if it sticks to the lower
right side of the device (opposite to the USB connector)
If it does not stick replace the b-cover with a good b-cover. Retest.
Testing
There are different tools available to test and repair the HDD. They are available from the User Interface (UI), through the “Mass Storage” USB selection when connected to a PC and through Phoenix test software. Depending on the level of corruption on the device, this will limit which
tools can be used. If the HDD is not accessible through the UI or the PC, then the last chance to format the HDD is through Phoenix
The Following 2 Users Say Thank You to DIGITAL BABU For This Useful Post:
Old 12-26-2009, 15:35   #10 (permalink)
Member: 1108123
Sonork: rishabh
nokian N91
Dear sir
Nokia N91 menu key ic all trak damege.
So menu key do not work.
Please Give me solution.
Regards
Gopal Oza.
Old 12-26-2009, 15:39   #11 (permalink)
Member: 1108123
Sonork: rishabh
Nokia N91 Menu key do not work
R4406 ic track damege. so give me solution argent
Old 10-04-2011, 07:28   #12 (permalink)
Member: 1472951
Sonork: keyur1212000
Thanks Meter: 2
where is the magnet in n91
Dear sir please say me where is the magnet in n91
N91 Problem to Detecting.... Gsm Lab MT-BOX 38 07-31-2007 08:52
N91 problem beega Nokia Base Band 5 ( BB-5 ) 0 12-12-2006 08:50
Route 66 on N91 Problems alpinanady Nokia Multimedia 3 08-30-2006 18:07
N91 problems........... tostefo MT-BOX 3 06-30-2006 00:49
Page generated in 0.32229 seconds with 9 queries
