Old 05-01-2008, 11:38   #1 (permalink)
joni_yang's Avatar
Member: 560754
Thanks Meter: 289
NEED 6120c LIGHT/LED SOLUTION
DEAR ALL,
MY 6120c DISPLAY AND KEYBOARD NO LIGHT/LED
ANY BODY HAVE THE SOLUTION.....?
ALREADY CHECK/CHANGE THE COIL...STILL SAME PROBLEM!
joni_yang
The Following 2 Users Say Thank You to joni_yang For This Useful Post:
Old 05-01-2008, 14:12   #2 (permalink)
raselopu's Avatar
Member: 485407
Sonork: 100.1580486
Thanks Meter: 183
change led driver ic. if doesn't work then follow schematic and bring two 6 leg ic controls this function and repair their legs if dried.
The Following User Says Thank You to raselopu For This Useful Post:
Old 05-01-2008, 14:57   #3 (permalink)
joni_yang's Avatar
Member: 560754
Thanks Meter: 289
already change bro...any solution?
thanks
br
joni_yang
The Following User Says Thank You to joni_yang For This Useful Post:
Old 05-02-2008, 08:44   #4 (permalink)
joni_yang's Avatar
Member: 560754
Thanks Meter: 289
no other solution?
br
joni_yang
Old 09-09-2008, 10:46   #5 (permalink)
Member: 225443
solution
[quote=joni_yang;3284951]no other solution?
br
chang betty IC
The Following User Says Thank You to sanoos For This Useful Post:
Old 09-11-2008, 13:57   #6 (permalink)
Member: 856796
Thanks Meter: 40
change lcd,,thats all
The Following User Says Thank You to bearhug For This Useful Post:
Old 09-11-2008, 16:02   #7 (permalink)
vinay_sharma's Avatar
Member: 309398
Sonork: 100.1590052
Thanks Meter: 5,455
Originally Posted by joni_yang View Post
DEAR ALL,
joni_yang
http:///vbb/showth...t=vinay_sharma
The Following User Says Thank You to vinay_sharma For This Useful Post:
Old 02-28-2010, 12:01   #8 (permalink)
Member: 1203799
Thanks Meter: 2
which is the led drive4r ic?
The Following User Says Thank You to naveenrafii For This Useful Post:
Old 02-28-2010, 12:06   #9 (permalink)
Member: 1203799
Thanks Meter: 2
Old 03-01-2010, 17:06   #10 (permalink)
kashantariq2002's Avatar
Member: 1019981
Thanks Meter: 98
change battery ic and post result
The Following User Says Thank You to kashantariq2002 For This Useful Post:
Old 03-01-2010, 19:49   #11 (permalink)
Member: 723358
Thanks Meter: 7
chang the betty ic ..........
The Following User Says Thank You to haarees For This Useful Post:
Old 11-11-2010, 14:02   #12 (permalink)
fizzo's Avatar
Member: 53864
Thanks Meter: 7
6120c
6120c disply light prob.
The Following User Says Thank You to fizzo For This Useful Post:
Old 03-15-2011, 10:12   #13 (permalink)
jahednn's Avatar
Member: 790856
Thanks Meter: 532
DEAR ALL,
joni_yang
post by ashad420
Nokia 6120c complate light solution.
Old 03-15-2011, 10:18   #14 (permalink)
jahednn's Avatar
Member: 790856
Thanks Meter: 532
and 2nd post solution......
Old 03-15-2011, 10:19   #15 (permalink)
Member: 148333
Thanks Meter: 14
thank you my brthar i m chiek
1110 i 12 1200 display light no need coil/trans/led/res/pf 1000000% Solution /\/\A/\/| Nokia Hardware & Hardware Repair 17 10-15-2011 10:13
Need 6120c LCD Light Solution abdurrahimsagar Nokia Hardware & Hardware Repair 5 09-05-2010 14:13
6120c lcd led and key pad light ways Mind Power Nokia Hardware & Hardware Repair 0 09-18-2009 01:30
6120c lighting problem solution pls??? roney_nexus Nokia Hardware & Hardware Repair 3 09-09-2009 04:40
Need K700i keypad led solution! N761 Sony Ericsson Hardware Repair 0 07-31-2006 03:02
Page generated in 0.22737 seconds with 9 queries
