11-02-2007, 11:21 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: Tanzania
Member: 271974 Status: Offline Thanks Meter: 97 | 5200 big problem |
11-03-2007, 00:44 | #2 (permalink) |
No Life Poster Join Date: Mar 2004 Location: cYBER sPACE
Member: 56855 Status: Offline Thanks Meter: 77 | [QUOTE=juniour member;2839310]ur battry conactor is foulty plz replace it best regards I encountered the same problem. If bat connector is faulty then how does it work ok without sim? I think another cause. |
11-03-2007, 01:32 | #3 (permalink) |
Freak Poster Join Date: Jun 2004
Member: 70463 Status: Offline Thanks Meter: 6 | Software.... have you try flashing the phone in othe box reset all settings like lifetime timer ect.? if you sure that you already done all software Hardware.... 1st is to check your battery a lot of battery has good voltage using VOM but current problem,2nd thing is to check your power amplifier reason why the phone shot off because the phone doesnt have enough power to register to network... Good Luck!!! sanflora [email protected] [email protected] |
11-03-2007, 06:00 | #4 (permalink) |
No Life Poster Join Date: Jul 2005 Location: ludhiana~india Age: 38
Member: 163833 Status: Offline Sonork: 100.1579554 Thanks Meter: 5,700 | brthr it is a hardware problem .... 1.check sim tray.... 2.. battery connector..... 3..chek or change sim ic.... 4..reball retu..... good luck |
02-22-2008, 21:31 | #8 (permalink) |
Freak Poster Join Date: Apr 2007 Location: UIO - EC Age: 37
Member: 483230 Status: Offline Thanks Meter: 25 | YEAH... CHECK THE RF CIRCUIT, MAYBE IT'S ON A SHORT CIRCUIT... IT CAUSES THAT THERE IS NOT ENOUGH POWER TO TURN ON THE PHONE... CHECK N7520, L7520 AND N7505 WITH THIS SCHEMATIC... http://rapidshare.com/files/47185701...Schematics.rar (Schematic by ArchitRaj) BR |
03-05-2008, 12:20 | #11 (permalink) |
Freak Poster Join Date: Mar 2006 Location: rajkot (india)
Member: 244357 Status: Offline Thanks Meter: 70 | may be it was hardware problem because there was shorting in your network section, when you switch without sim the network section will be inactivated,therefore it is don't off, and when you switch it on with sim the power is pulling by network section. therefore it get off. so try to change bettery and then try to check the shorting in the phone. good luck |
big problem with my mx key | sshreesai | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 03-31-2010 10:07 |
6085 big problem | kami1987 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 03-29-2010 13:42 |
5200 - big problem. please help! | memeh | Nokia Hardware & Hardware Repair | 0 | 05-14-2008 18:46 |
Big problem after using nss and nsu to update nokia 5200 ! | vettorodrigo635 | Nokia Base Band 5 ( BB-5 ) | 3 | 06-14-2007 06:28 |
big problem for 5200 and 6131 | mbourtelephone | MT-BOX | 3 | 06-12-2007 14:19 |
