Old 07-24-2003, 15:09   #1 (permalink)
D-Brain's Avatar
Member: 7301
Unhappy NOKIA 5210 Microphone fault
Hi All!
I have a NOKIA 5210 with very bad discontinuos and distorted audio from microphone.
Already tryed changing mic, resoldering cobba and making a software upgrade to v. 5.25 with no results
Any advice?
Bye n ThankS
LuKe ((d-brain))
Old 07-24-2003, 20:31   #2 (permalink)
Elco's Avatar
Member: 19254
Sonork: 100.72990
Thanks Meter: 25,395
reflow or replace cpu.I have same problem som time ago,solved with brand new cpu.
Old 07-25-2003, 09:44   #3 (permalink)
D-Brain's Avatar
Member: 7301
thanks, I'll try to change CPU, even if it's not easy to find as spare part
Old 07-28-2003, 07:52   #4 (permalink)
Registered User
mr_x4you's Avatar
Member: 4989
Thanks Meter: 13
try to remove cobba, then measure if tracks from mic. get to corespondent balls from cobba
Old 07-28-2003, 09:25   #5 (permalink)
Member: 14004
Thanks Meter: 6
Change bottom shell or reflow cpu!
I hade more than 10 nokias 5210 with this problem, i have repaired about 60% of them with reflowing CPU.
First i tried changing mic, COBBA, bottom plug-in connector,
all smd in path of microphone, CCONT.... nothing heleped.
Other 40% repaired with changing bottom express-on shell!!!
Old 07-28-2003, 09:54   #6 (permalink)
Registered User
mr_x4you's Avatar
Member: 4989
Thanks Meter: 13
Hmm, very strange problem !
Old 07-29-2003, 18:19   #7 (permalink)
vule's Avatar
Member: 10854
Sonork: 1578988
Thanks Meter: 3
Hiya
Check microphone bias....on 8210 it was resistor and 2 caps on keyside...
It might been same on 5210...I don't have board to check right now so this is just guess....
Vule
Old 07-30-2003, 00:09   #8 (permalink)
Member: 14004
Thanks Meter: 6
Originally posted by vule
Hiya
No, this is not the solution... I have allready tried that.
I think it is DSP problem because mic signal is breaking when other party talks louder. If signal form speaker is louder, mic signal breaks up (other party hears breaking voice)...
Other thing i noticed - this problem is present only with phones that don't have glued CPU.
So, this leads us to conclusion - CPU fault, probably solderings under MAD2...
Regards!
Old 12-02-2008, 15:31   #9 (permalink)
saqib_islam's Avatar
Member: 446881
Thanks Meter: 707
Hey Brother's Your Problem Is 100% Soved Here. Just Check it Out.
Nokia 5210 Mic Microphone Ways
Mobile Repairing Picture Help
5210, microphone too loud? sjakie Nokia Hardware & Hardware Repair 1 12-02-2008 15:29
E90 microphone fault repair Raheeeeb Nokia Hardware & Hardware Repair 7 10-07-2007 20:31
NOKIA 2650 microphone problem andr3as Nokia Hardware & Hardware Repair 8 11-08-2006 06:32
Nokia 6310i Microphone not work when is on carinstalation floky Nokia Hardware & Hardware Repair 1 09-06-2005 09:07
E700 microphone fault? jtg SYSOL Platform 6 10-06-2004 21:22
Page generated in 0.25019 seconds with 9 queries
