07-19-2011, 15:53 | #1 (permalink) |
Registered User Join Date: Jan 2008 Location: Where never ends.
Member: 669673 Status: Offline Thanks Meter: 301 | 5233 only vibrate i did all step by mahbubalfa in hardware section but i could not solve my problem. when i was flash mobile with usb cable mobile showing white display while flashing. mobile does not enter in local mode. have any solution? |
07-19-2011, 16:43 | #3 (permalink) |
Member: 669673 Status: Offline Thanks Meter: 301 | after success flash mobile still in vibrate condition here is log- ATF Software Version v7.65 ATF Lightning FBUS Flash Started... Number of Image Files: 4 Processing Image File : C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-625\RM-625_21.1.102_prd.core.C00 CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 13000000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 401 Entry Point: 0x288C52 Page Format : -1 MAX PAGE : 0x00040000 Changing MODE : FLASH AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ************************************************** **** TIME STARTS HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 400C1921 ID DWORD 4 : 01051105 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000296 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 2200010B ID DWORD 1 : 9A9E0052 ID DWORD 2 : 4B249F23 ID DWORD 3 : 74742547 ID DWORD 4 : CA40CCBD 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : B8 C3 AD EC FC 99 7F CD 80 81 D3 DE AF 87 0B 8C 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 4B9B7510 CRC 1 : 3E691FF8 Checksum 51 SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_2nd.fg Boot File - Version 011.016.00 Boot File - Revision 0x0002 (2) eBB5ProtocolType == New PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C Transmission Type Request Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : 06 SubBlocks : 06 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0400 -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> not used Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0040 -> KAT00F00RA Extended/Fixed ID : 0000 Revision ID : 0231 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 Block Length : 09 BB ASIC Index : CMT 00 Data : XSR 1.6 Checksum : 13 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files MuxOneNAND (03) ManID :00EC DevID :0040 ExtID :0000 RevID :0231 Flash Descriptor Manufacturer Code : 00EC Device ID : 0040 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 10000000 (256 MB) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_XSR17_alg.f g Algorithm File - Version 011.016.00 Algorithm File - Revision 0x0002 (2) eBB5ProtocolType == New Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok... VPP Enabled by Software Using Internal VPP VPP Enabled by Software FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: 7DC72D3FDC552426A4479BC820097D304CFB6C15 Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) Certificate 1 Name : NPC ASIC Index : CMT 0 Certificate 2 Name : CCC ASIC Index : CMT 0 Certificate 3 Name : HWC ASIC Index : CMT 0 Certificate 4 Name : R&D ASIC Index : CMT 0 STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3 STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Partition Version : 00010000 Spare : FFFFFFFF Num Partitions : 00000004 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 RO Start Address : 00080000 Size : 02700000 Partition 2 ID : 00000004 DEMANDONOS Attribute : 00000002 RO Start Address : 02780000 Size : 076E0000 Partition 3 ID : 00000008 FILESYSTEM Attribute : 00000001 RW Start Address : 09E60000 Size : 05620000 Partition 4 ID : 0000000A PMM Attribute : 00000001 RW Start Address : 0F640000 Size : 003C0000 PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF00000004000000030000 00020008000002700000000000040000000202780000076E00 00000000080000000109E60000056200000000000A00000001 0F640000003C0000EF PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) StartErase_DCT5... BlockLength : 0x5F (95) ERASE Blocks : 0x02 (2) 0 ERASE_AREA_BB5 0x12 Block Length : 0x2B (43) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 00040000-00082FFF 1 : 00083400-003FFFFF 2 : 00400000-007FFFFF 3 : 00800000-00D5FFFF 4 : 00D60000-09E5FFFF 1 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID : 0x02000000 Format Info : 000000000000000A0000000000000002000000640000000B00 000002000000010000000000000000 Erase_SendEraseBlock_BB5_NAND Task in Progress... Please Wait... Erase_SendFormatPartition_BB5_NAND Task in Progress... Please Wait... Successfully erased.. Time Taken to Erase : 00:00:01 Flashing Speed: 5.00 Mhz (AUTO) Processing : RM-625_21.1.102_prd.core.C00 Total blocks to write : 401 >> CMT Rootkey Hash CERT : ADA >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : RAP3NAND >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS >> CMT Rootkey Hash CERT : SOS*UPDAPP >> CMT Rootkey Hash CERT : SOS*ENO >> CMT Rootkey Hash CERT : SOS*DSP0 >> CMT Rootkey Hash CERT : SOS*ISASW >> CMT Rootkey Hash CERT : SOS+CORE >> CMT Rootkey Hash CERT : SOS+ROFS1 ContinueFlash_DCT5 Complete Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:54 Processing Image File : C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-625\RM-625_21.1.102_C02_prd.rofs3.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 13000000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 29 Entry Point: 0x00D7 Page Format : -1 MAX PAGE : 0x00040000 NO PARTITION DATA FOR THIS IMAGE... StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 09160000-09E5FFFF Erase_SendEraseBlock_BB5_NAND Task in Progress... Please Wait... Successfully erased.. Time Taken to Erase : 00:00:00 Flashing Speed: 5.00 Mhz (AUTO) Processing : RM-625_21.1.102_C02_prd.rofs3.fpsx Total blocks to write : 29 >> CMT Rootkey Hash CERT : SOS+ROFS3 ContinueFlash_DCT5 Complete Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:03 Processing Image File : C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-625\RM-625_21.1.102_prd.rofs2.V21 CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 13000000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 51 Entry Point: 0x00D7 Page Format : -1 MAX PAGE : 0x00040000 NO PARTITION DATA FOR THIS IMAGE... StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 06CE0000-0915FFFF Erase_SendEraseBlock_BB5_NAND Task in Progress... Please Wait... Successfully erased.. Time Taken to Erase : 00:00:00 Flashing Speed: 5.00 Mhz (AUTO) Processing : RM-625_21.1.102_prd.rofs2.V21 Total blocks to write : 51 >> CMT Rootkey Hash CERT : SOS+ROFS2 ContinueFlash_DCT5 Complete Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:07 Processing Image File : C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-625\RM-625_21.1.102_001_000_U001.uda.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 13000000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 23 Entry Point: 0x00D1 Page Format : -1 MAX PAGE : 0x00040000 NO PARTITION DATA FOR THIS IMAGE... StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 09E60000-0F47FFFF Erase_SendEraseBlock_BB5_NAND Task in Progress... Please Wait... Successfully erased.. Time Taken to Erase : 00:00:00 Flashing Speed: 5.00 Mhz (AUTO) Processing : RM-625_21.1.102_001_000_U001.uda.fpsx Total blocks to write : 23 ContinueFlash_DCT5 Complete Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:04 Total Flash Write Time (Flashing Only) : 00:01:09 Total Flashing Time (Booting + Erase + Flashing) : 00:01:11 Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000002 Additional Bad : 00000002 Correctable ECC : 00000000 FlashInfo.RestartMode : 2 Waiting for Phone to Go Online... Elapsed Time: 1s Elapsed Time: 2s Elapsed Time: 3s Elapsed Time: 4s Elapsed Time: 5s Elapsed Time: 6s Elapsed Time: 7s Elapsed Time: 8s Elapsed Time: 9s Elapsed Time: 10s MCU Version: V ICPR72_10w21.3.1 08-09-10 RM-625 (c) Nokia IMEI Plain : 353********** IMEI Spare : A35********* IMEI SV : 335*********F Phone Model: Nokia 5233 Product Serial Number: MOJ512039 Product Code : 0594741 Module Code : 0204424 Basic Production Code: 0587946 Default SN Type : 0 PPM Version : V ICPR72_10w21.3.1 08-09-10 RM-625 (c) Nokia HW Version : 0201 RFIC Version : 17141716 DSP Version : ICPR72_10w16p1 Content Pack Version : v 001_000 11-05-10 vanilla RM625 AHNE Version : 11 APE SW Core Version : V 21.1.102 APE Variant Version : V 21.1.102V 21.1.102 V 21.1.102 APE Test Version : eno_version Retu Version : 16 Tahvo Version : 22 APE HW Version : 256 APE ADSP SW Version : 256 ******** Reading SimLock ******** CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : ENCRYPTED PHONE_MODE : TEST MODE FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK have any idea for this problem solution? |
07-20-2011, 12:10 | #4 (permalink) | |
No Life Poster Join Date: Jul 2005
Member: 161646 Status: Offline Thanks Meter: 111 | tested by me post result Quote:
5110/6110 after unlocking see only network to which it was locked and ... | 2M | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 07-25-2000 00:51 |
Only MAX232 ??? | AMIGO | Nokia Hardware & Hardware Repair | 7 | 04-12-2000 09:41 |
only 1800Mhz ?? | dofie | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 01-17-2000 21:51 |
£20 only NOKIA 51xx/61xx sp locks 1,2,3,4 removed | spterminator | Main Sales Section | 0 | 08-08-1999 05:08 |
i can unlock nokia 51xx/61xx sp locks 1,2,3,4 £40 each £30 bulk for u.k only | spterminator | Main Sales Section | 0 | 08-01-1999 05:46 |
