02-29-2008, 03:37 | #1 (permalink) |
Freak Poster Join Date: Feb 2005 Age: 39
Member: 119200 Status: Offline Thanks Meter: 56 | 6020 works on the cable only the phone works only by the cable of any flasher tool(mt hwk jaf) but never works with any battery NOTE power buttom is ok you can power on off the phone using the power key but only with flasher tool cable too u can power on the phone using the power supply i had changed uem but the same anybody can help |
02-29-2008, 07:00 | #4 (permalink) | |
Freak Poster Join Date: Aug 2007 Location: just learning Age: 45
Member: 560754 Status: Offline Thanks Meter: 289 | Quote:
2.check uem ic,if not ok change it good luck.... br joni_yang | |
03-01-2008, 08:20 | #6 (permalink) |
Member: 119200 Status: Offline Thanks Meter: 56 | 3 pins psi already well conected i know what u r talking about but notice if the middle pci not conected the phone can't power on by the power supply this phone i have to connect the 3 pins to gives me local mode on the power supply. any other soloution thanks to all. |
03-20-2008, 07:49 | #10 (permalink) |
Insane Poster Join Date: Jul 2006 Location: uae Age: 46
Member: 321538 Status: Offline Thanks Meter: 10 | in this problem the switch ways, the battery terminals are all ok contacts and to the proper ckts. i think the problem may be the communication between the cpu and the uem. may some one think about it and isolate the fault |
Rolis Flasher don't work on one partition, but works on the other... | GeeZuZz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 07-26-2002 00:43 |
Only ON/OFF button works on the T28 ??? | TheEckoMan | Old Ericsson Phones & Sony Phones | 1 | 12-25-2001 09:23 |
Only ON/OFF button works on the T28 ??? | TheEckoMan | Sony Ericsson Hardware Repair | 2 | 12-21-2001 22:26 |
